No stereo really, a CD player and 2 front speaker, no amp lol. Eboost runs off it and standard accessories, that's about it. A mate works in spare parts and has priced up all the cables, battery clamps and isolator switch etc. I don't drive the car very often either. Maybe try to start it fortnightly for a bit and go for a short drive but that's about it, track days are pretty few and far between really. In the HR31, there are pits on either side of the boot, one to hold the space saver and the other side for tools and jack so if the battery fits, it may go in there. I don't intend on smashing it so should be safe enough there? It would restrict any movement should the bracket fail for whatever reason.
The under car would be quicker but if you hit something or catch it underneath very dangerous. Its a little bit more pain to put the cable through the car but will look a hell of a lot neater, almost factory. And be a hell of a lot safer then having it dangling under the car. For an extra 30min or so of mucking around its well work the effort. To make it quicker you could always take out all your seats ba the drivers one before you come here. Then we can pull the carpet back that way and will be a lot quicker and easier :)
I was thinking of at least pulling the rear seat out before I bring it. I know that's the easy bit. When I have all the gear together I will send you a PM and work out a time and date. I have got a fair bit on in March, going away for F1 weekend and also a weekend away for an engagement party, working a weekend in between etc but we will be able to work something out somewhere along the line. I'm all for neat work btw lol.
If you're only running standard cd player and accessories then 0 gauge might be a bit overkill as Johnny said. I reckon you can easily get away with 4 gauge and will reduce the cost of cabling a bit more.
Luke - were you planning on running the positive directly to the alternator?
On my 32 i ran the positive to the starter and alternator plus the fuse box. Ill have to see where the factory wiring goes from the battery, essentially the easiest way is to take the feeds from the original +v terminal directly to back of starter or alternator. Alternatively you could put a kill switch in the engine bay or "iso" with 1 side comming from the boot and the other from the original +v cables running from fuse/starter and alternator.
  • 1 month later...
Update, taken all of your advice in to consideration. I have the positive and negative cable, battery clamps, other u-clamps, kill switch and just ordered the Optima D34 :).
Battery isn't expected to be here until March 31st so not sure if it will all be done before the track day on April 23. Once this is done I can book the car in with Jez for the plenum install and retune. Happy times.
Luke, I will PM you once the battery is here and work out a day to get this done! I do like how you did it in your 32. Where did you get the black cable protector from?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
