No stereo really, a CD player and 2 front speaker, no amp lol. Eboost runs off it and standard accessories, that's about it. A mate works in spare parts and has priced up all the cables, battery clamps and isolator switch etc. I don't drive the car very often either. Maybe try to start it fortnightly for a bit and go for a short drive but that's about it, track days are pretty few and far between really. In the HR31, there are pits on either side of the boot, one to hold the space saver and the other side for tools and jack so if the battery fits, it may go in there. I don't intend on smashing it so should be safe enough there? It would restrict any movement should the bracket fail for whatever reason.
The under car would be quicker but if you hit something or catch it underneath very dangerous. Its a little bit more pain to put the cable through the car but will look a hell of a lot neater, almost factory. And be a hell of a lot safer then having it dangling under the car. For an extra 30min or so of mucking around its well work the effort. To make it quicker you could always take out all your seats ba the drivers one before you come here. Then we can pull the carpet back that way and will be a lot quicker and easier :)
I was thinking of at least pulling the rear seat out before I bring it. I know that's the easy bit. When I have all the gear together I will send you a PM and work out a time and date. I have got a fair bit on in March, going away for F1 weekend and also a weekend away for an engagement party, working a weekend in between etc but we will be able to work something out somewhere along the line. I'm all for neat work btw lol.
If you're only running standard cd player and accessories then 0 gauge might be a bit overkill as Johnny said. I reckon you can easily get away with 4 gauge and will reduce the cost of cabling a bit more.
Luke - were you planning on running the positive directly to the alternator?
On my 32 i ran the positive to the starter and alternator plus the fuse box. Ill have to see where the factory wiring goes from the battery, essentially the easiest way is to take the feeds from the original +v terminal directly to back of starter or alternator. Alternatively you could put a kill switch in the engine bay or "iso" with 1 side comming from the boot and the other from the original +v cables running from fuse/starter and alternator.
  • 1 month later...
Update, taken all of your advice in to consideration. I have the positive and negative cable, battery clamps, other u-clamps, kill switch and just ordered the Optima D34 :).
Battery isn't expected to be here until March 31st so not sure if it will all be done before the track day on April 23. Once this is done I can book the car in with Jez for the plenum install and retune. Happy times.
Luke, I will PM you once the battery is here and work out a day to get this done! I do like how you did it in your 32. Where did you get the black cable protector from?
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
