No stereo really, a CD player and 2 front speaker, no amp lol. Eboost runs off it and standard accessories, that's about it. A mate works in spare parts and has priced up all the cables, battery clamps and isolator switch etc. I don't drive the car very often either. Maybe try to start it fortnightly for a bit and go for a short drive but that's about it, track days are pretty few and far between really. In the HR31, there are pits on either side of the boot, one to hold the space saver and the other side for tools and jack so if the battery fits, it may go in there. I don't intend on smashing it so should be safe enough there? It would restrict any movement should the bracket fail for whatever reason.
The under car would be quicker but if you hit something or catch it underneath very dangerous. Its a little bit more pain to put the cable through the car but will look a hell of a lot neater, almost factory. And be a hell of a lot safer then having it dangling under the car. For an extra 30min or so of mucking around its well work the effort. To make it quicker you could always take out all your seats ba the drivers one before you come here. Then we can pull the carpet back that way and will be a lot quicker and easier :)
I was thinking of at least pulling the rear seat out before I bring it. I know that's the easy bit. When I have all the gear together I will send you a PM and work out a time and date. I have got a fair bit on in March, going away for F1 weekend and also a weekend away for an engagement party, working a weekend in between etc but we will be able to work something out somewhere along the line. I'm all for neat work btw lol.
If you're only running standard cd player and accessories then 0 gauge might be a bit overkill as Johnny said. I reckon you can easily get away with 4 gauge and will reduce the cost of cabling a bit more.
Luke - were you planning on running the positive directly to the alternator?
On my 32 i ran the positive to the starter and alternator plus the fuse box. Ill have to see where the factory wiring goes from the battery, essentially the easiest way is to take the feeds from the original +v terminal directly to back of starter or alternator. Alternatively you could put a kill switch in the engine bay or "iso" with 1 side comming from the boot and the other from the original +v cables running from fuse/starter and alternator.
  • 1 month later...
Update, taken all of your advice in to consideration. I have the positive and negative cable, battery clamps, other u-clamps, kill switch and just ordered the Optima D34 :).
Battery isn't expected to be here until March 31st so not sure if it will all be done before the track day on April 23. Once this is done I can book the car in with Jez for the plenum install and retune. Happy times.
Luke, I will PM you once the battery is here and work out a day to get this done! I do like how you did it in your 32. Where did you get the black cable protector from?
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
