Level 28. grind leveling is the fastest way to level - Confirmed
With about 8 hours worth of grinding I got from level 21-28. anywhere in between 65-85k experience an hour (roughly 1 3/4 levels an hour). In a really experienced guild who on their off time research better ways to level / build their characters so that of course bumps off onto guild members.
If anyone would like to join there are grind parties anywhere from level 10-45. Let me know :)
Don't really see the point of elder scrolls, if you gotta pay a subscription may as well just play THE mmo (wow)
probably the same shit as wow just scaled down because its new.
I don't want to be 'that' guy but yeah, might as well just stick with playing wow on and off (like 3 months on 9 months off after i get bored of it generally lol) happy to be proved wrong though, do they have trials?
Edited by UNR33L
ESO isn't WoW - similar but quite the different game.
From the WoW players I've spoken to they enjoy both games but sick of WoW so made the change. No trial version as far as I'm aware. Best bet is to watch twitch.tv and try and take your best guess from there if you don't have a m8 where you can try it out.
Love the "server maintenance" at 9:30 -10pm last night
Bastards
lol
Consider yourself lucky :P Last server maintenance we had was 12 hours long. LOL
People had the ability to log into other peoples accounts from just logging in with their own deets. They could also drop, trade, sell or buy with other's accounts. So that 30min maintenance felt like a gift :P
Bahaha at level 31 I got teleport. MUHAHAHA I can now spam port about 10 times before magika runs out - this is without magika regen - so quite possible can use it 15-20 times which would get me around... 200-300m :D
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
