Hi guys,
I removed my front upper control arms but not 100% certain how they sit back in the car...if I look at fitting the left arm first, I think the cotter pin sits on the inside of the strut with the small nut facing down, is this correct?
Also, do I fit them as pictured where the pin mounts are offset or do I spin the unit on its thread axis 180 degrees so that the pin mounts are aligned to the each on the face side?
I think you will find comparing them against the stock arms most instructive. The alignment (or offset) needs to look the same. Per this http://i9.photobucket.com/albums/a55/tamiya_S2000/1992%20Skyline%20GTS-t/d5da7a6a.jpg
As to which end goes inwards...I dunno. I can't remember if the lengths of the inner bush and outer bush are the same, which would be one key way to determine which end is which. The other way to look at it is.....the cotter isn't used to lock them up for length is it? In which case, it simply might not matter where it goes. Provided you can unlock the nuts and spin the centre, it should work equally well either way - also provided the ends are parallel and the offsets are equal (which I think they probably are - it's been a while since I've handled an R32 upper.). If you need to access the cotter, put it where it is easiest to get to.
Edited by GTSBoy
Both the bolts for the front uca are different diameters. Larger diameter bolt is the inner. Inner bushes are slightly longer too. That should tell you what way they fit.
Edited by H4x
Thanks for the info guys, they are the first version arms. Do they bend on the GTR as well? This is obviously concerning...
Here comes the something I cannot explain. I have reinstalled the factory upper arms which measure approx 175mm centre to centre from the pivot holes (versus the uas arms which measure approx 155mm centre to centre) yet with the factory arms camber is huge as the top of the rims sit about 10mm furtherinside the guard!?
Edited by Marko R1
Here's mine. Its about 165mm center to center, which was for 3deg neg camber at about 635 ride height (too low, one of the reasons its apart atm)
Oh and as the series 1 arms are clearly not "fit for purpose" Pelican should swap you to series 2 for no cost!
Re: the length - urrr.... remeasure?
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
