I have inserted the acronym GAFU into my Mech Eng List Of Terms dictionary :(
Back on topic - Dean, I'll find out tonight/tomorrow about the Garrett wastegate actuator (cost, part no: etc).
Ram in more pressure than the stock injecotrs can handle and the spray pattern of the injector gets all ***ed up and all the injectors spray pattern wont be the same.
You didnt see this happen in perth did ya??? coz perth seem to always get the most stupid figures out of stock parts which dont seem possible :D
makes more sense having the engine failing due to ***ed up spray patterns rather then staying open(running rich)
If you are going to port and polish the intake, why don't you go the whole hog and get it Extrude polished or whatever they call it.
Get your throttle body, inntake manifold, runners and head and take it to them. They then pump the stuff full of this "Gunk" which is abrasive and smooths the path in the direction which the air will flow.
I think its about $330 to do it....
BASS OUT
Hi guys, ok thanks for the responses.
I think they have high levels of Nitrous in the air down in perth, lucky bastards :D
SK: U mentioned a place to get Rb25 injectors, can u tell me pls?
Matt: Thanks for the info on the w.a. I agree the rb20 wont suffice.
Steve: Hmm is 040 a better fit, otherwise i might get some prices of jap brand pumps.
At current, I am speaking to Bill from ATS in regards to hiflowing the stock turbo, and see what options i have. Will be lookin at min of 250rwks.
Will there be any difference between a decent EBC and the PFC EBC in performance. I assume that the PFC will work better with the EBC it was designed with?
Thanks for all ur responses guys :D
I just finished an exam, so in a happy mood :rofl:
Cya
For more comprehensive ecu data-logging.
if you want the engine to last using the stock injectors at 260rwkw is not the way to go about, full stop.
:werd:
-rb25
Steve, thanks ill keep that in mind, cmon currency rate, go aussie dollar :D
Leo: Read this thread by BOOSTD, http://www.skylinesaustralia.com/forums/sh...ht=%24350+turbo
I am basically goin to do the same thing but with a different V-trim, and different machining, which is still to be decieded. Ill let u know once i myself know. Shoudnt cost more then 600 for the turbo work, and that is probably worst case senario.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
