Well, the discussion had gone through the points of shorting the battery not mattering (to the ECU) and why welding could be a bad thing. As such, the concept of 12v being the killer was no longer pertinent (at least to this discussion).
Yeah i think i'm saying no shit because you don't think i could possibly understand that a welder puts out a lot of voltage....sorry thats the way you came across to me.
When a workshop welds on your car's exhaust etc, they fit a surge protection device across the battery terminals.
These days everything is DC so you never hear of alternator diodes cooking, was very common back in the AC welder days.
I'm yet to receive an iron clad guarantee from any workshop that if they blow my ecu they'll replace it.
So I unplug mine.
No I was just thinking that you'd skipped over the fact that we were talking about welders by that time.
So it's impossible to damage the ECU then by shooting the battery.
True as long as the engine is not running. Any changes to battery connections (including that tool generated short circuit) when the engine is running can create load dump whiich has been defined by ISO and SAE to be as much as 270 volts. Latest numbers have lowered that to (if I remember) something just under 100 volts.
Automotive electronics therefore also meet higher voltage requirements. For example, 5 volt regulators must withstand something like 60 volts without damage.
Never make electrical changes (not including a jump start) if an engine is running.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
