Its DECA time. And once again i ask for your help
As stated above Saturday 22nd of March
We are after a group of 10 volunteer Officials.
The roles will be for Timers / Starters / Marshals
Most important are the morning events we only need 4 people to help out in the afternoon.
We would need all officials to be at the DECA complex at 8 am and be ready for the officials briefing at 8.45 am.
So if you are not entered and are just coming up for a look we really need your help.
Lunch and drinks will be provided on the day.
So if this sounds like you or you are bringing someone up that can help let me know.
Cheers WayneO
MORNING.
Official 1..Wayne
Official 2..David
Official 3
Official 4,,Anna
Official 5 .Lee
Official 6
Official 7
Official 8
Official 9
Official 10
LUNCH..
AFTERNOON
Official 1..Wayne
Official 2..Tony
Official 3
Official 4
https://www.sau.com.au/forums/topic/439803-deca-volunteers-officials/
So not needed in the arvo anymore? Will see if I can get the for the morn runs.
Tony
if your not getting up to DECA until lunch time and you can help out in the afternoon only that
would be great . Come find me when you get to DECA.. :thumbsup:
MORNING.
Official 1..Wayne
Official 2..David
Official 3
Official 4,,Anna
Official 5 .Lee
Official 6
Official 7
Official 8
Official 9
Official 10
LUNCH..
AFTERNOON
Official 1..Wayne
Official 2..Tony
Official 3
Official 4
As you can see we are short on volunteers. Not a lot will happen on the day without them.
And the longer it takes for me to find and arrange people on the Saturday morning the
latter we will start.
Just saying.
Tony
Done and done. If I can get there any earlier I will. Where abouts will you be so I can find you a bit easier? Maybe wearing a red hat or such :P
  • Like 1
He'll have an orange vest on, probably on skid pan shouting but if you see anyone with an orange vest ask them :)
Hi wayne, Im bringing two of my mates along. Im putting there hands up for them for volunteering if you get desperate (looks to be that way)
provided they can still get some passenger runs in i dont see why they cant do it!
...provided they can still get some passenger runs in i dont see why they cant do it!
Help will be most needed during morning session, so passenger runs in the afternoon shouldnt be a problem.
That would be great Josh.. i will track them down.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
