I have a 1992 R32 GTST broad minded person
The passenger head light was out so I changed the bulb... Didn't work
Changed the fuse and it worked
Then blew the fuse
Changed the fuse again and it worked till I flicked my high beams on
Blew another fuse,
Changed the fuse again and checked the wiring, but now that light doesn't work at all and isn't blowing the fuse
Low and high beam don't work
Parker light does
Only on the passenger side, drivers side is fine...???
What should I do? What should I check and how do I test? Help!
https://www.sau.com.au/forums/topic/439858-r32-gtst-need-help-guys/
Change the headlights switch (remove surround, unscrew switch, screw in replacement switch, plug in and test). If you want to take things a bit further (you should always upgrade ;)), wire up some relays for your headlights.
I'm glad you found a broad minded R32. Some tend to be narrow minded and dicks. My R32 is trying to kill me via it's HICAS, pretty sure it doesn't like curries :P.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
