wanting some advice on mufflers here...
currently i have 3 inch from the downpipe all the way back to a cobi resonator and then out an RPS muffler at the back. I've been thinking about changing the cobi to another muffler instead of a resonator so i've been looking at those.
a couple of questions
has anyone used a borla, vortex or a flowmaster muffler on an RB before?
is there any reason why you wouldn't use these? n/a vs turbo muffler etc?
https://www.sau.com.au/forums/topic/439901-muffler-selection/
There is no such thing as a turbo muffler.
There are mufflers of various sizes with various levels of flow and sound attenuation. The bigger and less restrictive the flow path through the muffler the less the attenuation. You can get away with a bit less attenuation in a turbo car because the turbo itself does some silencing.
All it really means is that a muffler that is low restriction is better suited to a turbo than an NA if noise is a concern. Both engines benefit from having as little restriction as possible, turbos possibly benefiting more than NA.
yes... technically they dont call it a turbo muffler just a muffler suited for turbo applications...
also less restriction the better in general BUT I believe for NA cars, the exhaust system is more critical as in, they plan for the bends, lengths etc to encourage a better scavenging effect since the pressure of the gases leaving the cylinders is not as pressurized as a turbocharged car. this is probably why when u put ur hand at the exhaust opening (when its not so hot), u can feel the gases coming out in pulses..
at least thats wat i have read so far... :)
i guess you're hitting the nail on the head...what makes a turbo muffler a turbo muffler? is it a straight through design? if thats the case many mufflers can be used.
for turbocharged exhaust systems, scavenging effect is less critical i believe... thus designers usually just want straight pipes with minimal bends... thus they usually point sideways near the rear of the car...
as for the internals of the muffler... most aftermarket ones are straight thru with steel wool etc... totally unlike ur OEM designs... which are misaligned /disjointed pipes with tons of sound deadening stuff in the middle...
Correct design for NA exhaust is that you have to get the primary lengths and the secondary lengths right (and the diameters right to get the velocities into the right range) in order to get your pulse tuning. After the collector at the end of the secondaries, you don't want to go too big a diameter pipe (in the aim of minimising restriction) because you still want to retain a decent gas flow velocity in the downstream pipe.
Turbo exhausts just want to get as big as practical as soon after the turbine as practical in order to get the back pressure as low as possible. A really excessively big diameter exhaust on a turbo that didn't need it to be that big might hurt power......maybe...... from the gas speed being too low and causing some problems that some people talk about but I have a hard time imagining. But in general that size is probably bigger than what you can actually fit into most cars anyway.
Back pressure is a bit of a crock, it hurts power production on any setup.
On a turbo the rear housing is already a restriction causing back pressure, go too small and you lose top end flow and engine torque.
On an NA a restriction should be built into the merge collector imo, not in a reduced exhaust size for the entire exhaust length. The worst idea I have seen is those X pipes some of the V8 guys use, which apparently help with creating vacuum before the X for a reduced flow. Siamese merge pipes are much better design imo as they don't harm exhaust flow.
Hey Scotty, how much benifit do you think there is in have a merge in a V8 exhaust system?
My old mans designing his set up atm and is deciding on whether to put a merge in or not.
Engine a 500ci+ producing around 700-800HP. Primaries are 2.25 into a 3.5" collector down to twin 3" pipes.
Any tips or recommendations on mufflers?
Yep, look up what a Siamese merge is, it's just a small slit between the two pipes, barely affects flow, but causes each pulse to create vac in the other pipe. Take some inspiration from the merge collectors on Burns Stainless site, they are some of the best I have seen.
Don't use Hooker mufflers, they have restrictors in them to quieten the exhaust volume. I gained 30kw changing to a Varex, both running 3.5 inch. Any straight through absorption muffler should be fine, the quality decides how long it lasts.
Is anybody still running a standard system?
my s1 Stagea still has the Nissan exhuast on it, with whatever cat they fit during compliance.
it's all 2.5" stainless and very well made, nice bends, well mounted etc.
As you'd expect from Nissan!
Only mod I've done is remove the "p&o cruise ship" rear muffler and fitted a 2.5"id- 4.5"od stainless eBay cannon and everyone asks if it's full after market as its reasonably loud.
You have a stock stainless system? Must be rare, I have never seen one on a Stagea before. If it is a Jap system it won't be 2.5 inch, they only use metric tube. ;)
V8 Soarers have stock stainless, as did the Golf I worked on the other week. Not many manufacturers use it due to their bean counters.
Sorry, 63mm then?
it has the Nissan emblem on the mid muffler box and on various bits I can see the Hitachi/unisia symbol.
And it definitely is stainless.
I also had (previously owned) a Holden hsv VS manta, and it had a pretty nicely made twin 2 1/4" stainless system.
But probably only due to being a HSV model. As it had HSV embossed in big letters on the muffler boxes.
Edited by nicksamaniac
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
