I am putting my money on it being boost cut. I am with Superben, I bet this bloke is looking at the boost gauge thinking its in psi
Do yourself a favour and find a local Skyline specialist and get them to set the boost up on the dyno.
Badgaz, are you really saying that modifying a car to fix a problem is a good thing? You should never do that. You should always start with a perfect running car and modify from there. Installing mods to cover up an issue is only going to end in tears
i think what i'm really saying is ...when factory items break thats when you should improve/modify them.....in this case the factory ECU is broken because he wants to modify his car :woot:
Is this issue occuring mostly in first and second gears?
Was having the exact same issues in my 94 33 gtst and I was sure i was onlt running 9/10PSI until I went on a dyno, I wound it back about 2Psi down to "8" and the guy said it was doing 10psi on the dyno so it was more like 12psi instead of the 10 i thought. Since then havn't had that issue.
There's some stuff to try in this thread:
http://www.skylinesaustralia.com/forums/topic/32356-missfire-boost4500-5500-rpm-the-answer-for-me-at-least/
What are your plugs gapped to? I had the same misfire and going from a gap of 1.1 down to 0.8mm solved it for me.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
