Update on prices. All items are plus postage.
KKR660 turbo - $150 - to my knowledge in working order, was left in a workshop and I managed to score it.
R34 GTT door trims - $50 - small pieces missing (i.e. part of one handle, reflector/light)
Stock R34 GTT springs - $30 - nothing wrong with them, replaced with King Springs
Stock R34 GTT front brake rotors - $30 - only removed because upgraded, car had 150,000kms, unsure if machined before.
Stock R34 GTT stock brake lines - $10 - replaced with braided lines.
Stock R34 GTT front swaybar - $100 - only removed due to upgrade.
Stock R34 GTT rear swaybar - $100 - only removed due to upgrade. (both for $150)
Also got all this audio stuff...
Alpine V-Power 2/1 channel amp (MRP-T220) - $40
Stinger 0 gauge t-piece/distro block x2 - $10ea
0 gauge fuse holder with 250A ANL fuse - $15
2m 0 gauge cable brown - $15
1.4m 0 gauge cable red - $10
4m 0 gauge cable red - $40
4.5m 0 gauge cable blue (very bendy) - $50
1.5m 14 gauge speaker cable - $5
9.5m 14 gauge speaker cable - $25
S15 rear speaker covers - $5
2m 4 gauge conduit/1.8m 0 gauge conduit black - free with any other cable
Bump want this stuff gone.
KKR660 turbo - $100 - to my knowledge in working order, was left in a workshop and I managed to score it.
R34 GTT door trims - $40 - small pieces missing (i.e. part of one handle, reflector/light)
Stock R34 GTT springs - $20 - nothing wrong with them, replaced with King Springs
Stock R34 GTT front brake rotors - $20 - only removed because upgraded, car had 150,000kms, unsure if machined before.
Stock R34 GTT stock brake lines - $10 (or free with rotors) - replaced with braided lines.
Stock R34 GTT front swaybar - $90 - only removed due to upgrade.
Stock R34 GTT rear swaybar - $90 - only removed due to upgrade. (both for $120)
Alpine V-Power 2/1 channel amp (MRP-T220) - $30
Stinger 0 gauge t-piece/distro block x2 - $15 for both
0 gauge fuse holder with 250A ANL fuse - $10
2m 0 gauge cable brown - $10
1.4m 0 gauge cable red - $5
4m 0 gauge cable red - $35
4.5m 0 gauge cable blue (very bendy) - $45
1.5m 14 gauge speaker cable - free with anything else
9.5m 14 gauge speaker cable - $20
S15 rear speaker covers - free with anything else
Bulk buy all audio related gear for $120
All items are plus postage, happy to work out a deal.
We also have an official SAU.NSW Swap Meet in the western suburbs of Sydney on 27Th April if you'd like to consider...
See NSW > Events
Cheers. I would go if it was a 4.5hr drive away :P
I also have a Defi BF 60mm Tacho to sell. White backlight.
Perfect working order. Selling because it came as part of a set I bought 2nd hand and the seller wouldn't seperate the tacho and I have no need or want for it. Chasing $150ono plus postage. Can post pics on request but figure it's pretty generic. Will include stand and link cable.
  • 3 weeks later...
  • 4 weeks later...
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
