strutto.... use the Fast setup program, that's installed with FAST to choose a Japanese Unicode Font.
That way the characters won't look like jibberish it'll be japanese unicode character.
pentae, i'm not talkin about Silvia K's, I'm talking about the KRPS13 etc...
here's a lil sumfin 4 u to chew on :)
S13's
KRS13 - 180sx w/ CA18DET and 4WS
KRPS13 - 180sx w/ SR20DET and 4WS
RPS13 - used for the 180SX Type S and 180SX Type G with the SR20DE. Used as well for the 180SX Type X w/ the SR20DET
KS13 - Silvia J's and Q's had CA18DE w/ 4WS. Silvia K's had CA18DET w/ 4WS
S13 - Silvia J's and Q's had CA18DE. Silvia K's had CA18DET
KPS13 - Silvia J's and Q's had SR20DE w/ 4WS. Silvia K's had SR20DET w/ 4WS.
PS13 - Silvia J's and Q's had SR20DE. Silvia K's had SR20DET.
S14's
CS14 - Silvia J's and Q's had SR20DE w/ 4WS. Silvia K's had SR20DET w/ 4WS.
S14 - Silvia J's and Q's had SR20DE. Silvia K's had SR20DET.
And now here's the codes you will see on the 240's here in the US.
S13's
PS13 - 240sx coupe w/ KA24DE
S13 - 240sx coupe w/ KA24E
KRPS13 - 240sx fastback w/ KA24DE and 4WS.
RS13 - 240sx fastback w/ KA24DE.
S13 - 240sx fastback w/ KA24E.
S14's
S14 - 240sx with KA24DE
Capish?
  • Replies 83
While sittin here doin buggery till my shift's over, I got around to installing the system so I could check out the VIN number screens. After a lot of squinting and scribbling down Kanji on pieces of paper, here's the first two screens decoded.
May 1989 - August 1991 VIN Numbers
Pos 1 = Body Shape
K = Hardtop
Y = Police Car
Blank = Sports Sedan
Pos 2 = Engine Type
F = CA18 Model Engine
H = RB20E Model Engine
R = RB20DE, RB20DET Model Engine
B = RB26DETT Model Engine
Pos 3 = Suspension Setup (An educated would make me think this is supposed to mean Steering Setup)
Blank = 2WD with no Super HICAS
C = 2WD with Super HICAS
N = 4WD with Super HICAS
Pos 4 = Number of Doors
Blank = 4 Door
R = 2 Door
Position 5 = Vehicle Description
D = GXi
G = Y (Police Car), GTE, GTS, GTSt, GTS-4
X = GTR
Pos 6 = Transmission
F = 5 Speed Manual
A = 4 Speed Automatic
Pos 7 = Fuel Equipment
E = EGI Type
I = SPI Type
S = Intercooler + Turbo Type
Pos 8 + 9 = VS Sign
Pos 10 + 11 = Pack Sign
Pos 12 + 13 + 14 = Personal Sign
August 1991 - November 1994 VIN Numbers
Pos 1 = Body Shape
K = Hardtop
Pos 2 = Engine Type
F = CA18i
H = RB20E
R = RB20DE, RB20DET
E = RB25DE
Pos 3 = Steering Setup
Blank = 4 Door
R = 2 Door
D = GXi
G = GTE, GTS, GTSt, GTS 25, GTS-4
X = GTR
B = GTR with 17 Inch Wheels
F = 5 Speed Manual
Y = 5 Speed Automatic
E = EGI Type
I = SPI Type
Pos 8 + 9 = VS Sign
oi adrian, how'd you get to that screen?
Enter only the model series (R33) and hit OK...
Go to the abbreviations menu and choose model 1-13 digits, or model 14-18 digits...
If you enter a VIN, it only displays the codes for that particular series...
The Model Number Reference Illustrations for the 33 are no where near as comprehensive as for the 32... :rant:
Anyway... On with the show... I did what you said Shan and for your edification and enjoyment, here are the first 13 model codes (in Japanese) for the R33...
Go forth and translate my people!
7 more digits innit? that decoding I gave you in my PM wasn't off fast, it was off a list that someone posted up that sorta guessed at what it might be by looking at the differences in the VIN numbers of different cars. Its not wrong, but not that accurate either.
figured out why the R33 vin numbers weren't working on my system, its coz they're all in A2, and for some reason it's not loading A2... grrr... I've set it up properly and all...the archive is fine as well, might have to get a copy off a mate or somehting...
rest of the R32 translation comin up
Ive currently only got a1.rar loaded..
and when i click..
Search > Models on CD ..
That will only show me the models that are in the A1.rar correct?
If so, has anyone decoded this list? .. If not i will translate it tomorrow for you guys.
let me know before hand so im not translating somethign thats already translated :D
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
