Rb26 aftermarket and standard engine parts!!!
R34 Gtr cam and timing cover $370
Arp head studs rb26 $170
Garrett 2860-5 turbos mint $1400
Greddy t517z turbos great condition one turbo rebuilt $1250
Tomei sump baffle $180
Nismo fuel reg $100
Denso 800cc injectors rb26 $400
Splitfire coilpacks $340
Manley rods h beam used rb26 $450
Mahle forged pistons 86.5 rb26 $450
Rb26 block 86.5mm bore mint $280
R32 Gtr crank $150
Rb26 sump with diff $150
R34 Gtr coilpack cover $110
Rb20 rb26 engine mounts like new $100
R33 Gtr alternator 90amp $70
Rb26 bottom baffle plates $20
Rb26 cas $70
Rb26 r32 Gtr balancer $40
Engine brackets $40
Rb26 standard rods $40
Many other parts available
Gold Coast
0487924497
What are your best price for the pair of these? These are direct replacements correct for the RB26 - running N1 turbines... please do confirm with me and let me know.
Thank you!
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
