I'd reckon 6th gear in the Tremec would be pretty much redundant for track use. Ratio selection/spread for 1-2-3 looks to be an improvement. Torque-load capacity obviously is a plus, so the things that I'd like to know is
1. how it handles quick-ish changes at high engine speeds
2. whether this box has its own selection of little components that fail like those little spring clips in the R33 box
3. how difficult/expensive is it to give a Tremec a freshen up if bits do get tired
4. how difficult/expensive is it to engineer a Tremec into a R chassis
Not being negative, and I appreciate that Stuart is having a go at building a better package within a sane budget. Mostly I want to know if it's the sort of upgrade I would want to do. :)
Hey noddy, the issue u were having with the rb25 box failing, was it typically going up the gears ie from 3rd into 4th or going down the gears from 4th to 3rd when it would fail? Thanks
What does the initial damage? Probably a miss shift up to third. There is an awesome technical little track in Stanhope that is all 2nd and third gear. Twice over the last 10 years I've come away snicketty from there where I know I rushed the up shift and forced it in. At morgan park and lakeside on a down change to 4th a similar problem where I didn't get a big enough blip in and rushed the synchros.
Putting the third brass guide at the top definitely helped. We replaced the side ones too, they are pretty wrecked in most of the boxes we see. post-15176-14237442983836_thumb.jpg
Why go to a T56? Well, my gearbox guy did all the development work for MallWood and has had a lot of experience with them. They normally have a number of Teflon parts that he has replaced with various metals. He has a few tricks up his sleeve that have gone into this box.
The other major factor was that I was so over the 25 box. A bit over 12 months ago I sourced a late model (2000) 34 box and gave it all the things we have learnt over the last 8 or so years. 1st meeting of 2014, ttt weekend at morgan park, Saturday was just cruising through the gears beading it in. Sunday, 1st run 2nd lap up to 4th nice and easy.... crunch, and got worse every lap. The dogs on 4th were chewed to hell. Went hunting for parts and ended up with brand new 4th gear and selector hub.
Shared the car at a mate who has been racing since the late 60's. I was racing he was doing a super sprint. We bedded the box in Friday practice and it felt really good. After the 2nd round on Sunday... bag of dicks. Some how bruce killed it.
Went hunting and found a nice 32 GTR box to use, gave it all the tricks and raced at the lakeside classic. No practice so panzied through qually to bed it in. The race meeting went well, no issues, but I just didn't like the feel of it. Didn't touch the car again until the end of the year for a sponsor ride day at QR. It was fine.
I spent the year racing my TRD Japan built AE86 and building a new motor for the 33. The new 30-26 should push a bucket load of torque. 9.2:1 comp, 1 mm oversize valves 88mm pistions 256/272 big lift cams with trust manifold and a pair of TD05's. What is going to stand up to the grunt, handle the race track and fit the budget?
Edited by Noddy
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
