Hi all,
I am taking out the drive shafts to replace both inner CV Boots on an R34 GT-R. I have taken out the passenger side drive shaft out no worries but I am having difficulty pulling out the drivers side. Going off the workshop manual for an R32 GT-R (cant find R34's) it says that you have to drain oil from Front Diff, remove cover, remove C-clip then wedge out the drive shaft...
My problem is removing the front diff cover. I have unbolted all 10 x 14mm bolts holding the cover in place but the cover seems to be really sealed on to the diff & I just cant get it off :(
Anyone had this issue before? Any help/info/tips would be greatly appreciated :yes:
Cheers,
Glen
Edited by xanavinismo
Should just come off, its probably silicon holding it on, yes 10 screws after counting them on my diff..
Watch the breather tube on top too.
You just pry the shaft out using a big screw driver from inside the diff, the clip just hops over the cut in the shaft.
I am not certain that r34 is the same, but on 32-33 it is possible to remove it without removing the diff cover (bit late now!). You can pop the driveshaft out even if the circlip is in place using a pry bar. The other end is trickier, I've found the easiest is to remove the lower control arm at the ball joint at the hub.
Thanks for the feedback guys!
So where exactly do I pry it from? Eg - Up against the diff?
Also when it comes to putting the drivers side drive shaft back in, there wont be any issues with lining it up with the circlip inside the diff etc?
Cheers guys!
Glen
You just need to pry between the inner joint cup & the diff housing.
For refitting the shaft, ensure the circlip is a snuggish fit into the groove (if its not, then it will catch on the spline & be forced out of the groove & possibly damaged), start the splines in the carrier & drive/force it in BY HAND. The circlip will compress.
Do I also need to pull & rotate the driveshaft while prying? Because my problem is that the inner CV boot is completely split and theres nothing keeping the shaft in place :(
No, it should just pop out, its just a matter of finding the right place to lever. I have to do mine soon too, would have done already except for a back injury.
You can remove the shaft from the cup, just be careful as there are three races with needle rollers that can fall off (dont lose any, as re-assembly with just one missing means failure). Then you can pop the cup out of the diff.
After many attempts to pry the shaft out still no success :( So I moved back onto removing front diff cover...
Okay so I finally removed diff cover (ableit using a razor blade to cut the silicon bond in between the diff housing/case.
Next issue is where exactly do I pry from? The workshop manual for an R32 GT-R isnt showing exactly where to push up against...
Thanks again for the help guys!
sorry for the slow response....it must be frustrating getting stuck at this bloody spot!
Basically I would get a pry bar (maybe very small at first, maybe even a screwdrive if the fit is very tight) into the area pictured. The end of the drive shaft and the bronze coloured steel shield come out together, so get the bar underneath that bronzy disk and start prying. As it can require some force be careful.....levering stuff out is a really good way to hurt yourself when it does finally let go!
Or, since you have the cap off, in the diff centre as pictured are 2 small spider gears, the end of the driveshaft is inside the spider gear and you should be able to get something in there to pry it out too....the pic doesn't really show it because you are looking straight on, try looking from the right side back to the left and you should see the end of the shaft.
Failing all that....whereabouts are you? I'm actually in Canberra tomorrow night and can give you a quick hand if you haven't won....
I haven't done it on a gtr, but with the circlips holding in drive shafts prying as hard as you can sometimes doesn't cut it. A quick sharp blow on the pry bar shocks them free. Also when doing that push it in as far as you can so it gets a little 'run up' to pop out.
Yes very frustrating indeed :(
But wow what a coincidence, your in Canberra! Im up in the northside of Canberra. Would be really appreciated if you can come over and give me a hand! :yes: I can PM you my address...
I am happy to report that I have finally managed to wedge out the driveshaft! Wooohoo!
I did it via wedging from inside the diff with a small pry bar/screw driver & using a hammer to give it that shock to release the circlip, for me a much easier option then somehow prying like you guys. Hats off to those who are able to pull it out that way :yes:
Thanks again so much to all that gave me their helpful details/hints/tips!
Cheers,
Glen
  • Like 1
Good work! Some thought out hammer blows make all the difference.
Same goes for tight nuts, ball joints etc, a sharp blow works so much better than a levering action.
It's science :)
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
