Hi all,
I am taking out the drive shafts to replace both inner CV Boots on an R34 GT-R. I have taken out the passenger side drive shaft out no worries but I am having difficulty pulling out the drivers side. Going off the workshop manual for an R32 GT-R (cant find R34's) it says that you have to drain oil from Front Diff, remove cover, remove C-clip then wedge out the drive shaft...
My problem is removing the front diff cover. I have unbolted all 10 x 14mm bolts holding the cover in place but the cover seems to be really sealed on to the diff & I just cant get it off :(
Anyone had this issue before? Any help/info/tips would be greatly appreciated :yes:
Cheers,
Glen
Edited by xanavinismo
Should just come off, its probably silicon holding it on, yes 10 screws after counting them on my diff..
Watch the breather tube on top too.
You just pry the shaft out using a big screw driver from inside the diff, the clip just hops over the cut in the shaft.
I am not certain that r34 is the same, but on 32-33 it is possible to remove it without removing the diff cover (bit late now!). You can pop the driveshaft out even if the circlip is in place using a pry bar. The other end is trickier, I've found the easiest is to remove the lower control arm at the ball joint at the hub.
Thanks for the feedback guys!
So where exactly do I pry it from? Eg - Up against the diff?
Also when it comes to putting the drivers side drive shaft back in, there wont be any issues with lining it up with the circlip inside the diff etc?
Cheers guys!
Glen
You just need to pry between the inner joint cup & the diff housing.
For refitting the shaft, ensure the circlip is a snuggish fit into the groove (if its not, then it will catch on the spline & be forced out of the groove & possibly damaged), start the splines in the carrier & drive/force it in BY HAND. The circlip will compress.
Do I also need to pull & rotate the driveshaft while prying? Because my problem is that the inner CV boot is completely split and theres nothing keeping the shaft in place :(
No, it should just pop out, its just a matter of finding the right place to lever. I have to do mine soon too, would have done already except for a back injury.
You can remove the shaft from the cup, just be careful as there are three races with needle rollers that can fall off (dont lose any, as re-assembly with just one missing means failure). Then you can pop the cup out of the diff.
After many attempts to pry the shaft out still no success :( So I moved back onto removing front diff cover...
Okay so I finally removed diff cover (ableit using a razor blade to cut the silicon bond in between the diff housing/case.
Next issue is where exactly do I pry from? The workshop manual for an R32 GT-R isnt showing exactly where to push up against...
Thanks again for the help guys!
sorry for the slow response....it must be frustrating getting stuck at this bloody spot!
Basically I would get a pry bar (maybe very small at first, maybe even a screwdrive if the fit is very tight) into the area pictured. The end of the drive shaft and the bronze coloured steel shield come out together, so get the bar underneath that bronzy disk and start prying. As it can require some force be careful.....levering stuff out is a really good way to hurt yourself when it does finally let go!
Or, since you have the cap off, in the diff centre as pictured are 2 small spider gears, the end of the driveshaft is inside the spider gear and you should be able to get something in there to pry it out too....the pic doesn't really show it because you are looking straight on, try looking from the right side back to the left and you should see the end of the shaft.
Failing all that....whereabouts are you? I'm actually in Canberra tomorrow night and can give you a quick hand if you haven't won....
I haven't done it on a gtr, but with the circlips holding in drive shafts prying as hard as you can sometimes doesn't cut it. A quick sharp blow on the pry bar shocks them free. Also when doing that push it in as far as you can so it gets a little 'run up' to pop out.
Yes very frustrating indeed :(
But wow what a coincidence, your in Canberra! Im up in the northside of Canberra. Would be really appreciated if you can come over and give me a hand! :yes: I can PM you my address...
I am happy to report that I have finally managed to wedge out the driveshaft! Wooohoo!
I did it via wedging from inside the diff with a small pry bar/screw driver & using a hammer to give it that shock to release the circlip, for me a much easier option then somehow prying like you guys. Hats off to those who are able to pull it out that way :yes:
Thanks again so much to all that gave me their helpful details/hints/tips!
Cheers,
Glen
  • Like 1
Good work! Some thought out hammer blows make all the difference.
Same goes for tight nuts, ball joints etc, a sharp blow works so much better than a levering action.
It's science :)
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
