So I just finished putting a rb25 gearbox in my r32
Got the custom tailshaft to suite
But basically, I can put the car into all gears, while the car is on, and my revs don't change, it doesn't stall, it doesn't move at all. But I need to use the clutch to put it into gear
It moves ever so slightly then just nothing
My mate said my tail shaft is too short, but it splines onto the gearbox which I can easily tell, and I ran the car on jack stands with no tailshaft in, and the spline on the back of the gearbox spins
Does any one have any ideas :/
Have to use the clutch to put it in gear, thats not unusual?
cant you put the back of the car on standsso the wheels are in the air and then (carefully) put it in gear and have a look. Obviously if the tailshaft doesnt spin at all then it isn't engaging the shaft out of the gearbox. If you want to confirm this, you could use some spacers and longer bolts on the diff flange for the tailshaft so that the front will go further in the gearbox. Again be careful doing this, while on stands, and be gentle putting it into gear.
It's just something to check it, dont go driving around like that because its not good at all
And yeah haha I actually wrote in my first post I did that,
Thinking it may now be the slave cylinder, the pin is seized and isn't fully de compressing, leaving the thrust bearing pushing on the clutch still when the clutch pedal is disengaged
Being like that the clutch slips, so it grabs slightly but very weakly, which is my problem
If its a 25 box and the slave is stuffed, it means you wont get as much clutch disengagement rather then engagement. So you should have the opposite problem, hard to get into gears, but has full clutch contact when the clutch pedal is released. To confirm this you could just remove the slave and leave it hang. Then start the car in first with the wheels in the air and they should spin happily. Otherwise if its an issue with how much clutch slip it has (more then normal) then you could try the same thing but then try and start the car in first with it on the ground. make sure you have plenty of room obviously, because if it does start and the clutch is engaged it will move forward until you hit the brakes or turn it off.
what was the condition of the clutch that went in it? Was the gearbox known to be working before it went in the car? From memory the output shaft will spin a little bit with the car in neutral with no load on it
The clutch might have an issue
Clutch was good I've been driving with it for a year
Box came out a car I wrecked
If the slave pin isn't releasing all the way then it'll give me the issue what I'm having
That's a good idea about taking the slave of and driving it in first (or reverse for me as its in the shed..)
100% not a clutch issue (as in pressure plate clutch plate flywheel etc)
Definitely not a diff issue
One thing I noticed, when my rb20 was out, I could attach the box then the slave after,
With the rb25 gearbox on, I can't attach the slave cylinder after as its too stiff, which makes me believe it hasn't retracted all the way
So I believe th slave is stuffed
If that makes sense
Yeah might have a siezed or damaged slave. I got mine honed and re-sealed from a brake shop for $50. Looked and felt like a brand new one. They can re-sleeve it if the bore is to wrecked. Give that a go, sounds like it needs a rebuild anyway
Cheers for your help man I appreciate it
Took the slave out and wheels spun in gear as they should, fiddled with the slave and got it to retract properly and threw it back in, and car drove right for a minute before the slave got stuck again
Ordering a new slave today
May aswell just get a new one I suppose
I couldnt' source one locally and after having my car off the road for 3 months, and not wanting to wait over the weekend for parts, I thought it was better to just get it re-kitted. Only took them about an hour as well.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
