Have a few things to get rid of most pictured below - ALL ITEMS PICKUP ONLY - location Chermside and all in reasonably great condition.
Twin sub box 28cm holes - will fit in r33 boot $20
Bar size freezer $45
old working tv + stand + new set top box $60
6.2 channel sony surround sound home theatre speakers (no amp unit) $50
2 tall thin speakers with glass bases $40
sony speaker stands $15
vogel's evolution speaker stands $15
hp printer (no ink) $15
Take the above for $200 ($260 added up individually)
Also available:
Expandable timber dinner table $40
Lounge from Freedom furniture beige colour $$350 (New $1500)
Award winning designer chair set - Individual chairs sell at over $600 per chair online and cost $270 per chair wholesale these were limited production - Im selling 6 chairs for $900 and throwing in the design table that was used with them (these can be used as either dining or office) they are in great condition.
If you are interesting in EVERYTHING - $1200
Hoping to move within next week, if not sold will be putting into storage
thats the sony 6.2 channel surround speakers, 2x front speakers, 1x centre, 3x surround rear (left right centre) and 2x sub woofers - so $50 for the set they are in perfect condition the system cost new over $600
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
