Hey All...
I just bought new rims and tyres...
235/40/18 Front
265/35/18 Rear
Falken 326 i think??
I have noticed I have considerably less traction than when i had my stockies on, 225/50/16.
Do the new tyres have a certain amount of distance to be travelled before they start to grip or have i just bought crap tyres??
I was shocked at how easy it as to smoke the new tyres.. with the stock tyres i could just chirp second gear, but now when i slam into second gear i can smoke the rears quite a lot...
P.s i have 183 rwkw.....
i appreciate the advise...
https://www.sau.com.au/forums/topic/44069-wearing-in-tyres/
Thanks,
I was afraid of that... i was just supprised that my crap stockies had a noticable amount more traction even after i totally fried them on the figure 8 at the DECA day a couple of weeks ago!!!
P.s i think i saw your car at the Auto Elec a couple of months ago.... Very Nice! I had work done there on my car previously...
Cheers
https://www.sau.com.au/forums/topic/44069-wearing-in-tyres/#findComment-900545
Yeah, how much did you pay for them out of interest?
yeah my car was at the auto elecs a couple of months ago, so would of been mine :rofl: Thanks
Now you have bought the tyres, probably not much you can do... I'm about to try some hancook 104's, hopefully better than these 326's :(
https://www.sau.com.au/forums/topic/44069-wearing-in-tyres/#findComment-900549
Dunno about the 235's but know that i paid $250 for the 265's.... I was very close to buying the semi slicks but thought that by the time they warmed up and really started to grip my trip would be over... i was quoted $270 for the semi slicks (Falkens)...
ive been told the Hancooks are pretty good... so good luck.... im starting to think i should have just bought a new pair of 225/50/16's, as was always really suprised at the amout of grip they had.... For stock tyres anyway....
https://www.sau.com.au/forums/topic/44069-wearing-in-tyres/#findComment-900563
from SydneyKid:
Hi Matt, road tyres take at least 500 k's to "run in". They give off oil and other lubricants used in their manufacture. So they have to heat cycle a number of times to make sure the "slippery stuff" is cooked off. When they are new the more you "smoke em up" the worse the grip gets as buckets loads of lubricants all come out at once. So run them in.
https://www.sau.com.au/forums/topic/44069-wearing-in-tyres/#findComment-900696
yeah the tyres will get better after a few days....but 326s are really crappy tyres, that's why they are so cheap.....
better options from falken are st215s or even better FK451s. Still under $1500 per set but they actually have grip.
https://www.sau.com.au/forums/topic/44069-wearing-in-tyres/#findComment-900716
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
