Thought I'd share this engine with you...
442ci General Motors based OHV V8
- no gaskets, just heat expanding O-rings
- extesive use of titanium.
- fluid dynamic crank to cut through the oil easier at speed
- turbos similar spec to what is found on Indy cars
Capable of 10000RPM (not bad for a 7.2L engine)
Early dyno run @ 25psi
1820Nm @ 7500RPM
2140hp @ 9000RPM
aiming for 2800hp with the boost set at 35psi
just the ticket for getting to work in my R32...
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/
timbar32
it says 10,000RPM not 100,000RPM. Its not a turbine....
the type racing this will be used for involves a lot of runs per meet, so it has been engineered to produce this power consistantly with needing a rebuild every run.
Basically nothing in the entire engine is off the shelf. Even the cam is considerably thicker than in the engine its based on. The write up on this suggests rather extreme levels of engineering.
7.2L, 4 turbos & 10,000RPM would sound unbelievable on the track
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-900725
nah, the guy is fairly tight lipped about many of the exact details. there is just a repeated idea that 'it costs alot to run this sort of gear'. titanium valves, springs & retainers. billet ally/GRP rods, 55mm billet cam, magnesium/thin wall stainless turbos... its insane
i guess 'alot' would be quite an understatement
RB's are nice but i wanna turbo big block!
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-900831
iv heard about this car
that thing is street legal and competed in all the street legal drags around the states, for a little while but it was banned by all of them soon after haha just too farken quick lol :)
speaking bout big hp some guy accross east, managed to get a Marlin engine (spitfire from WWII) into a car, produces 3000hp. hehe crazy bastard!
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-901001
the 27L V12 Rolls Royce Merlin was in WW2 fighters such as the Spitfire, Mustang, etc. It was also used in tanks of the era.
Rod Hadfield of the Castlemaine Rod Shop fame has spent the best part of the last couple of decades engineering a Merlin into a '55 Chev body. Apparently it quite the animal. Its appeared on TV since its been finished but I still haven't seen it.
I was 15 last time I saw that car in the museum part of CRS & it was basically just a turret, chassis & engine.
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-901067
It was on tv ages ago, can't remember what for but he was having a good talk about it . Was awesome.
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-903737
Guest INASNT
That's Mike Moran's car + motor there, he's a leading edge drag racer in the states who always seems to be driving customer's cars for them. Then he decided to build a car for himself, and look what he got :D
Yep that car has been in a special zoom magazine drag edition last year!
It was pulling low 6 second 1/4 times in that same shell last year
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-904471
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
