Harro,
Item 1: NPC Carbotic Clutch Disc
Price: $300
Comments:
  • Thought my clutch died, turns out my clutch fork was fractured & my bearing carrier was the incorrect
  • Scott from Western Clutch measured it and said it's about 0.04mm worn only, near new
  • Disc is under 2 years old, has had about under 14000 km street driving and 3x track days, car makes under 200kW
Reason for Sale: Downgrade to a lighter disc that's more drivable for the street
Item 2: Toshi Remapped R33 Series 2 ECU
Price: $300
Comments:
  • Difference is day and night, others will understand
  • AFRs super safe, sits about 11.7~11.8 all the way at 0.9bar - has been taken to the track many times
  • Tuned for full exhaust, front mount, healthy fuel pump, and boost at 0.9 bar, ~13psi
  • Please check your base timing, set it at exactly 15 on idle with the TPS disconnected
  • Will install and check your base timing for free if you're local
Reason for Sale: New turbo & ECU
Item 3: Stock R33 Series II GTS-t Manual Radiator
Price: $50
Comments:
  • Decent condition
  • Doesn't appear clogged or anything
Reason for Sale: hast tag becauseracecar lol
Item 4: Stock R33 Series II Front and Rear anti roll bars / sway bars with bushing & brackets
Price: $80
Comments:
  • Decent condition
  • No cracked bushing
Link to other stuff for sale too:
http://www.skylinesaustralia.com/forums/topic/433062-fs-syd-r33-gts-t-part-brake-pads-subframe-collars-wheels-gauge-holder-misc/page-2
Contacts: PM or Reply Here
As always, will trade for beer and/or alcohol too :woot::woot:
Item 5: Stock R33 Series II Stock Turbo
Price: $250
Comments:
  • Comes with elbow
  • Has minimal shaft play
  • No funny oil leaks
  • Exhaust wheel has not fallen off yet LOL
Reason for Sale: hash tag becauseracecar lol
buy my shit, will trade some stuff for:
  • 2x NEW Nitto NT-05 in 255/40/17
  • 6x 1000cc OR 1200cc sidefeed injectors
What has been done to the ECU? Was it socketed for a programmable EEPROM or Nistuned?
hey mate!
Socketed ECU with a reprogrammed ROM
Don't think anyone has installed the new Type 6 Nistune for R33 ECUs yet, I know a few of the Stagea boys have though.
Yeah I have done up a Z32 ECU with a Nistune board... but I thought a quick ECU swap for more boost would be a nice thing. I don't have the cash for a tune (and possibly never will) and i'm maxing out the AFM at 11psi. =-/
MMMMM will the clutch plate work in a jim berry pressure plate
Dooo it!!!!!!!!
Also ECU sold :)
Can't see why not? After all NPC pressure plates are modified Exedy covers :)
Dooo it!!!!!!!!
Also ECU sold :)
Dammit...snooze you lose :domokun: was about to PM you :( Mayb I should just keep saving and go the way of a PowerFC.. Goodluck with selling rest of your goodies
buy my adaptronic ECU and it will come with a free modded car for $12k :)
I like breasts
Stock Turbo & Dump $250
Clutch $200
Stock ABS Diff $250
Stock Rad $20
New Braided Oil Feed $50
Stock Front and Rear Sways $40
Stock S2 AFM $50
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
