Hi guys.
Ive recently bought an auto 1998 stagea with a Neo rb25de and i have noticed that i have been getting around 280km to a tank, this seems pretty low even with around town driving?
I have run a diagnosis and it came back with code 55 which as i understand it means that it is all clear.
It doesnt run rough on start up or when warmed up but it does blow white smoke during high revs.
Possily a faulty o2 sensor??
Im new to the nissan game so just looking for ideas or advice.
Thanks
https://www.sau.com.au/forums/topic/440782-very-high-fuel-consumption/
That appears to be abnormally high, but might not be depending on how much fuel you put in the tank.
To be more meaningful it should be litres per hundred kilometers.
I would recommend replacing the O2 sensor on any old car as they all stop working.
Also checking the resistance of the ecu temp sensor (should be able to find that info online) or with a consult cable if you happen to have one checking what temperature the ecu thinks the engine is at when at operating temperature.
I would chuck some new plugs in it for the sake of it and check the timing is set correctly.
So it is non turbo?
So it is non turbo?
Thanks for the tips.
Its around 25L/100km i believe and yes it is non turbo.
That's way over the top. I get 12 - 15 l/100km from my RB30 turbo. You should be getting around 12.
On the other hand it is a heavy car and if you keep your foot flat like any car you can get poor mileage.
Replace the O2 sensor (don't think it will make a huge difference) and have a look at the plugs.
Jack the wheels up and make sure no brakes are binding.
Put a timing light on it (put a short lead between the coil and no 1 plug).
Make sure you are measuring the consumption properly (use the trip recorder of which there are two for some reason and calculate when you fill up again).
i thought my fuel consumption was high at ~ 13-14L/100km for a stock RS Four S turbo
i've been meaning to change O2 sensor but haven't got around to it yet . . .
Edited by Stooge007
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
