So you tested the spark at the plug yeah and no spark, was that with a new plug or the plug out of the cylinder covered in fuel
If an injector is locked open it will give similar results and foul the plug, if there is no spark with a new or known working plug then it's electrical, so if you have changed plugs - coils - loom - ECU, then what's left, would have to CAS
  • Replies 44
Ok thanks, I did a compression test awhile ago and numbers were good, but noticed the previous owner over filled the motor with oil and I drained some of it out and did a test again today and numbers did not look too good, I called it a day and I'm going to do another test tomorrow and see what that shows, I will do a compression test before and after I drop a cap of oil in the cylinder.
Get a LED test light and test what signals you have at the plug on the coil. You should have an ignition positive a ground and a pulse that is also ground on the externally igniter coils. Smart coils will have a positive pulse. Hope that is some help it's a very cheep and handy tool to have
Xklaba, the last compression test had shown that there was 135-140psi between all cylinders, but when I did that compression test it was really cold still I'm not sure if the cold would have effected the results by thickening the oil, bick033 I got a regular test light would that be fine? An oscilloscope is that just another word for timing light?
So I did a compression test and I got values starting from the firewall back, 105/140 after a cap of oil, 130, 150, 150, 145, 140. I didn't waste time putting a cap of oil in the cylinder that's at 130, or the rest of them
An oscilloscope reads the voltage signal wave and displays it on a sceen so you can see it to see what is getting sent to the ECU, completely different to a timing light
130 is low but not enough to kill the cylinder altogether, 140 is on its way to be low, 145 is exceptable, 150 is your norm with the tester your using, so you didn't put oil in any of the cylinders yeah ? What did you mean by 105/140 ?
With a normal test light it is hard to see a pulse because the filament takes time to fully go out so it will just look like it's on all the time it will be fine to use it will just look like a ground all the time when running.
Bick033 ok I'm going into town tomorrow and I will get one, I couldn't really put much time into the car today as that's all I've been working on all week, and this is my last few days off work and I will be gone away for awhile so I had to do some work around the acreage. I put the plug up agains the breather and couldn't see a spark, but I will go buy the oscilloscope tomorrow and try it
Be aware that we're talking about a couple hundred $$ worth of oscilloscope here. And a reasonable amount of assumed knowledge to be able to use it. They're not going to help the uninformed/inexperienced. Definitely a techie's toy.
Edited by GTSBoy
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
