I have seen on one of Robs builds he mounted it in the boot on that black bracing. I'll see if I can dig up some photos tonight.
Thats alot of extra engine oil to add and a long line going back with engine oil in it
Do you have enough room between the a/c condenser and intercooler. Also maybe under one of the guards in front of the wheel might work
I thought you would have to remove the condensor to do that I will look into under the guard cheers do you have one fitted
hey guys im fitting a accuusump i want to know what spec press sw i need to use ?
The three valves we have are 24-271 (20-25 psi EPC switch) 24-273 (35-40 psi EPC switch) and 24-275 (55-60 psi EPC switch)
which one guys as above in thread im running tomei oil pump
Your also paying him a lot of money for building your engine.
I would be seeking and using his advice even if it means it takes a bit longer to hear back from him.
True I am but I have been firing away too.many questions for the minute going to give him a call today for the first time
just a quick question with running a single turbo with ex gate do i need to run the factory bovs and pipeing ?
just get some custom piping made up. It will look 100 times better. As for the bov did you want it plumbed back in or atmo I have a turbo smart v port under the drivers side guard right under the head light facing up so if you look from under the car it's hidden. Also what ecu are you using one with a map sensor it's nice to scrap the afm also.
Im running a pfc djetro with twin maps yes . I will just plumb it back into the outlet on the turbo then just wasnt sure if they both were required the stock bovs are trust and proven I wont change out for aftermarket no need.
I'm also using the pfc dejetro but I'm only using one of the map sensors the other I wired to be used for boost sense. I would just use both of them twice as much air to flow.
Im running both of them they are already plumbed in ao I will leave them there. What type of car have you got and engine specs
I have a r33 gts-4 did have a rb26 conversion but now have a 25 soon to be 30 also. It's converted to just rwd now as it was planed to be a drift car but anyway engine specs are
S2 rb25det
6 boost with tial 44mm gate
KD t67 turbo
Full custom 3inch turbo back exhaust
Fredy plenum
Aeroflow fuel rail all speedflow fittings I'd 725cc injectors soon to upgrade to 2000cc
044 fuel pump surge take ect
Turbo smart fp800 fuel reg
S90 billet throttle body
Pfc dejetro with hand control,datalogit,boost control and wide band
GTR intercooler all 3inch cooler piping
Ls1 coils
Road tuned on e85 safe tune no knock over 15 ( I don't like to go over 30 using the pfc knock reading) and pretty rich will put it back on the dyno soon to get some numbers.
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
