Symptoms: Traction light is on, Slip light is on, Check Engine light is on
Computer: Power FC no hand controller
What I have tried: I have read up on line about the self diagnostics and am un able to get it to work by jumping the 2 spots on the diagnostic plug with a paper clip.
I switch the ignition on and get the paperclip into the last 2 slots and nothing happens. Is this because I have a power FC?
Can a leak in the power steering throw this problem?
I have checked coil packs and replaced spark plugs. The car drives but is very sluggish
https://www.sau.com.au/forums/topic/441008-self-diagnostic-assistance-r34-gtt/
If you can drop past Hampton Park I could plug the Consult3 into it...
Hopefully the PFC will communicate the way Nissan designed the stock engine ecu to, the rest of the computers should be fine to diagnose.
I dont think consult works with Power FC's, nor does bridging across the plug
This feature only works with the stock computer. This is why there is no aftermarket 'hand controller that plugs in the OBDII (?) Port
Thanks for your offer VQ35det but it looks like not event that might help at this stage.
89CAL - Will the power fc show where the problem is if I plug in a hand controller? Also is there any way that it can be related to the power steering leak?
It may show up in sensor/sw check, being that I've only ever dealt with R33 Power FC's which dont have to worry about T/C etc so I'm not 100% sure what differences there will be but, if its throwing a check engine light, most likely you will find the cause of this (if nothing else) on the Hand controller.
Usually a problem with a sensor or switch is the problem so sensor/sw check on the hand controller will show up (the problem sensor is highlighted in black) if there is one. Try and borrow one if you can and have a look
Had and still have a similar problem with my car, car drives fine but not Traction, ABS and the lights stay on all the time which is annoying. I could never find a real answer.
http://www.skylinesaustralia.com/forums/topic/407575-tcsslip-light-on-with-pfc/
Had a quick look at the wiring diagrams I have. They are for R33 so it may not matter/correspond with the R34 but anyway.
there is one connection from the ECU to the A-LSD/ABS (and probably T/C on R34) unit. The outputs to the dash lights comes straight from the A-LSD/ABS ECU so I wonder if the Stock Engine ECU sends a signal to the A-LSD/ABS unit that the Power FC isnt sending. Perhaps a signal to activate power to the unit.
So if you take your car for a drive and see if the functions are working. because your slip and T/C lights are on and I'm not sure if this unit is controlling ABS in the R34 (unless you have an ABS or similar light on?) you may have to try and do a burnout. If its not tuned you could try it on the grass :). See if the ABS is working as well.
Then if possible find the wire from the ECU, unplug the A-LSD/ABS unit and check for a voltage on that pin in the harness plug with the Power FC plugged in and then with the Stock ECU plugged in and see if there is a difference?
Sorry I cant tell you where the A-LSD/ABS unit is, what pin you need to look at, and what exactly you need to look for but its a start I guess lol
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
