Hey man I couldn't get tomei throttle coat from anywhere ....apparently tomei don't supply an MSDS (Meterial Safety Data Sheet) when they ship the product outside of japan so a lot of countries won't let it through customs. There are some substitutes available tho.... I used Loctite Moly Dry Film in an aerosole can, sprayed into the lid to make a small puddle and used a 50c paint brush to coat the butterfly's while closed. On tomei's website it said to only coat the butterfly's and around the shafts/bores where they go through the housings but because the Loctite stuff is aerosole its super thin compared to the tomei paste so like I said, I painted mine while shut to get a good layer on the butterfly and bore so it's got a definite seal when closed. I fully cleaned the throttles with a rag and some carby cleaner befor the coating of course and shone a torch up the plenum and could see light around each throttle. Now coated, you can't see any light from anywhere inside the throttles.
  • Like 1
I have seen plenty of side feed Skyline injectors lately showing signs of fine rust blockages in the filters, and only some of the injectors were blocked, some were clean. It could be worth dropping a few out to check...
I can only think of one other reason, head gasket...
hmmmm well it wouldn't surprise me if the head/block wasn't prepared properly prior to re assembly..........after asking around, i'm not the first person to have had big dramas with nizzpro's services..........
I always use Hylomar spray on my MLS gaskets. It fills up any imperfections and scratches.
At least you can do the head in the car, mine is an engine out job, and two head gaskets. :/
Not only did the head crack, but i have had a super bad sounding noise in the clutch/gearbox area recently.......apparently ARP flywheel bolts are actually too long for RB motors .........
the clutch and flywheel where loose on the back of the motor....... the threads in the back of the crank are completely fingered and the center guide is slightly mushroomed.... the flywheel had to be reemed off with two pinch bars therefor a complete rebuild is being undertaken............
Gutted man..........
I used ARP flywheel bolts on my RB25 and they were fine. The packet they came in said they were for a 3S-GTE (toyota 4 cylinder) but they worked perfectly for me. Exactly what bolts were you using? A rebuild is better than losing your feet.
i used - ARP Flywheel Bolt Set (102-2801)
we measured and checked the bolts against the arp website specs and they are exactly what the website said they should be...... which is 3mm too long in my crank.
very strange..........
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
