Hey guys
I rear ended another car today and was just wondering if its worth claiming insurance as the excess is at $1800 and wanting your comments on whether or not my damages are significant and how much it would cost forrepairs. The other car is fine just scratches so it shouldn't cost too much. I've uploaded a few photos below
My poor 34 ='(
Thanks guys!
Edited by skytan12
https://www.sau.com.au/forums/topic/441135-cosmetic-repairs-and-other-repairs/
I would be putting it through insurance if i were you!
Headlight, front bar, reo, bonnet etc etc will easily go over $1800 once all painted etc!
I thought you only pay the cost of repairs up to the excess amount, so if repairs are 1000 that's all it costs you . so if you think it's cheap, there's no reason to not go through your insurance company.
You can just go to a crash shop for a quote anyway.
Thanks guys!
I'm presuming it'll go over $1800 but just wondering how much it would go over that by because I would rather settle it between ourselves than go through the insurance company because I would have to pay a premium for claiming and etc...
I'll go get a quote today and see how much it'll cost me
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
