wow, no good at all. does anyone here know anything about that zooboo or whatever suzuki swift? it was doing 55.02 and has no aero or anything, insane
Must have had balls like watermelons.
Sorry guys, bailed after round 2. I was so busy faffing with my camera that I missed the round 3 call and just went home! 65 first time, 63 second time. Pretty confident I would get it down to 60 if I had a few more more seshs. I didn't feel like any were very clean. Also first time on the sprint layout-quite different! All in all, a good day though.
Also: There were more than 16 peeps weren't there?
i think that was just the sau/evo owners clubs results, you can all the results here:
http://racing.natsoft.com.au/results/
this works for most proper timed event at most tracks in aus
last I heard it was 330ish hp on a built 1.6 still fwd
Definitely still a 1.6 suzuki motor me and my mate were perving on it in the pits. (wether or not the actual displacement is still that I am unsure)
whatever it is, it is so quick, came from behind to beyond in my view in no time whatsoever haha
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
