I've got a set of 4 rims (no tyres).  Have all the centre caps and wheel and lock nuts.
One wheel has a gutter scrape, but nothing serious.
May be willing to sell depending on what you want to pay.
J
would u happen to have pics buddy? im quite interested but im not sure whats good money till i research more first. so yea let me know whats ur rough price and ill work from therE?
I've seen anywhere between $600 and $1200 since I've been on these forums.
I've got a set and if it's any help, I like having a spare set but want to get something wider so if you come across any 17" x 8" at a price you can afford let me know and we might be able to do a swap.
Just me being lazy.
Good luck either way.
600! wow! haha i didnt expect that much..cos mate of mine just paid like 350 for the set without tyres so i was thinking it might be ard there..hmmmand if its 1200 i think i can buy some japanese rims...i think if they cost that much they must be pretty good stuff huh? they look nice :D
I think $1200 included good tyres to be fair. Can you seriously get any 17" rims for that price? I had no idea. I'll just keep mine for myself then. They look really good on r33's and have Nissan on the caps which I thought made them worth something.
It took me ages to find a good set :D They are worth a heap more than $350 to me simply cause I had a hard time finding them :)
Shipping would be a bit expensive, although I've got a mate down Melb way that comes up now and again...
J
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
