For sale in SA
Car: Nissan Stagea WGc34 RS4-S SII
Drive train: 5 speed Manual AWD (R33 GTR drivetrain)
Engine: RB25Det NEO
Colour: Pearl White
Kms: 95500
Price: $12,000 ono
reason for sale: New vehicle has been ordered and is arriving shortly, moving away from the import scene for now.
Contact: 0413-145-430 or pm me here.
Modifications:
Full nismo/ HKS exhaust
Apexi aircleaner
Splitfire coilpacks
new BC racing coilovers (under warranty)
varrstoen 2.2.2 18X9.5" wheels in matte black
Hard race adjustable camber arms
Garage Impul bucket seats
Dayz front bar
6k xenon headlights
eyelids
New titanium window tint
Alpine headunit
Ok so i have bought a new vehicle which is soon to arrive (i will post a few updates of that but that for later ;) )
Ok so yes I am selling the stag, i have loved its practicality and it does haul ass. I did have plans to do some more upgrades but i am taking my money in another direction.
she is a factory manual Series II AWD which means its an R33 GTR drivetrain with an R34 Neo engine... works well.
it is still unboosted so its a stock engine really, coilpacks have been done aswell as the usual maintenance stuff but its stock.
i have just replaced all Diff and transfer oils/ gearbox oils, atessa fluid. just had it reallighned for slightly different camber, very lively in the turns.
I have some spare parts for it such as a Z23 afm aswell as a heap of spares like all the stock parts,
a full set of struts, exhaust, interior bits coilpacks ect. even stock wheels with potenza tires!
i have spend some time setting up the handling of the car and for a wagon she does really corner, test drives welcome, im usually in her as its my daily driver.
i have serviced it every 5000km and i have receipts for this as well as all the work done on the car. no expense spared on maintenance.
interstate byer freindly as i have everything to make it stock for going over pits, very easy to do if needed.
please have a look at the build thread, this will show you in-dept info good and bad.
http://www.skylinesaustralia.com/forums/topic/436212-white-goods-daily/page-4
sms me or pm me and buy a nice car!
ask for any picks you need. i have millions and can take anymore.
inspections welcome.
https://www.sau.com.au/forums/topic/441568-fs-manual-awd-stagea-wgc34-rs4-s/
sold and gone.
hopefully the new owner gets on here and we can follow some good updates.
i will be back here sometime in the future im sure.
7 skylines and a stag so far under my belt :P
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
