Hi guys,
Here's an electrical diagnostics challenge, I believe.
A few weeks ago, my fuel gauge started playing up. It basically went straight up to a 'Full' tank and stayed there, even as I used fuel.
Every now and then, after i start the car, it will drop to the actual fuel level. However, after 5 mins it will slowly creep back up again.
All of the fuel sender issues reported for R33 and R34 models (I have a R34 turbo coupe) seem to show the fuel level ok until half way, where it will stay, OR it will immediately drop to 0. I have not experienced this, so I want to see if anyone has had a similar problem they solved without touching the fuel pump and sender (I am not a mechanic, would prefer to avoid going there unless no one has any other ideas)
I noticed when i removed my back seat recently that when the engine is on (and even perhaps when priming the ignition?) there is a high pitched whine coming from the wiring/distributing harness halfway through the cabin on the drivers side (will post picture tomorrow in daylight). I'm thinking of hitting this with some contact cleaner?
Has anyone experienced anything like this?
Thanks!
Mick
I've had suggestions that it's coming out of the speakers, but i had RCA cables and remote running down one side that are unplugged at both ends, and no power wires at all.
For reference, took this into the mechanic today. At some point, the previous owner had messed around with the sender, and the two brushes connecting the float and the rods had one snapped off. My mechanic extended the snapped wire and put it all back together, and the gauge now reads permanently alright. The fuel gauge sometimes read correctly before when at a certain angle where the rod would travel and push against the broken wire.
However, the bracket holding the pump and sender in the tank had obviously been exposed to air/condensation, and have built up considerable rust. Rusty fuel got everywhere when the tank was opened up. Fortunately, the fuel filter appears to have been doing its job, though its looking a little old and will definitely be replaced in the next service in 2000kms time.
As for the sound, I swear that i can not hear the whine anymore. This will probably be fully muffled when i put the car seats back in
All up, $330 GONE! labour only. This is why we ask the forums first :)
Hope this helps anyone that may have similar issues in the future.
Mechanic himself suggested just wait till i come back in for the service and will have the car on the hoist - would you consider this important enough to move forward?
Are you talking about the intank filter or the one in the engine bay?
If in the bay, rip it off and slap in a new one. Cheap insurance.
Ryco Z200 and no naked Flames. ;)
  • Like 1
Just the engine bay one - will start lobbying mechanically minded friends to help, otherwise Taki (my mechanic at Perfect Run) does it for $90, which i'm happy to pay
  • Like 1
90 to change a fuel filter, your getting ripped hard.takes 10 mins to do. :-)
easy DIY to replace the engine bay fuel filter. Was one of my first maintenance jobs, and im not very mechanically hands-on. Only annoying thing was getting the hoses off the filter, but it eventally came off with enough force lol.
Alright gents, you've encouraged me to give it a crack. I feel comfortable knowing that if i do f**k everything up, at least only the engine will die, and i most likely wont :thumbsup:
Edited by Lolrick
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
