I was palying with car i didnt plug MAFS back in properly drove car then relized i FKD UP..I plugged it back in properly i tyred to use my OBD11 Tool but it keeps coming up
LINKING ERROR...I was thinking of trying to clear it by discontecting battery or is it best to take to electrition n see if there tool can clear it..
I have just got into this type of car and learning thats why i tryed it .And new to this Forum....Ihave been into valiants for 30 yrs hyundai excels pug 206 gti .this is new ...We are not all experts ...Scotty...
Fare enough but i have joined some forums and because they know all they treat nebies like children,,Im a bouncer mate i dont like people talking down to me ..KEYBOARD HEROS I HATE..
...Thanks for help... But YOUTUBE works like always...lol
I never said you were, but a simple search in the correct V35 forum would have sorted you out quickly.
With the little amount of information you provided I am guessing you have a 2.5 or 3L? No OBD2 readers will work, as they aren't OBD2 compliant. (even though they have an OBD2 plug.) You can drop the battery terminal for 6 months and the fault will still be there, you either need to do the pedal dance to manually clear it, or use one of the limited units that will talk to your ecu, namely the Consult3 unit, Snap-on, Osirus or Launch Diagun. They are all fairly expensive but only the Consult3 will communicate with all the ecu's in the car.
Youre the hero mate, just trying to help ffs.
I think I am supposed to get scared, more so than his keyboard antics warrant.
Fix it yourself, the hammer is over there mate.
To think... I was going to invite the bouncer here for an ecu reset on the Consult...
Ken, I'll give you a couple of tips.
If asking a v35 question, go to the v35 section. It will get answered quicker, and there is a great search function that would have answered your question if you used it.
Second. Nothing stirs "keyboard warriors" up like someone who try's to act tough over the internet. Nobody cares you're a bouncer. This is a car forum, not an nightclub. Leave the attitude behind.
Welcome, I hope you find the information on v35s helpful.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
