Hi All,
I have the following stuff to sell all pickup in Canberra / QBN.
Price is make are offer on here or via PM... My R33 is sold so no longer needed, this stuff will either be ebayed or thrown out
Stock Airbox with high performance filter... good condition
http://imgbox.com/sf**kqx1
Reverse switch (that controls the reverse lights) Brand new genuine nissan.
http://imgbox.com/xqypXZoU
Plastic Box for POD
http://imgbox.com/oFvc0G3k
Clutch and Fan. Clutch is stuffed!!
http://imgbox.com/THybj6ju
RB25det Head... great condition
http://imgbox.com/sKfHLg24
http://imgbox.com/0YnUVuNc
R33 s2 stock exhaust... all the way from dump pipe to back.. good condition
http://imgbox.com/l0c2GHWp
R33 S1 ABS pump... OK condition should work fine though never tested (i had a s2)
http://imgbox.com/eAV1Owii
R33 Stock wheels
http://imgbox.com/vM0IGwzw
http://imgbox.com/WbVGV2uA
R33 Emergency tyre
http://imgbox.com/bmxZHrPT
https://www.sau.com.au/forums/topic/442043-r33-parts-for-sale/
Hi All,
Plastic Box for POD
R33 Stock wheels
R33 Emergency tyre
And this should be an rb25det block for sale above not head!!
  • 4 weeks later...
I have a feeling that the pod box might be missing a piece... cant find the instructions. bought off ebay for $110 how about $20?
As for other stuff ill put up some indicative prices.... I really have no idea what things are worth everything is pickup only.
SOLD
$30
Plastic Box for POD
$20
Free with any other purchase.
$100
$50
$40
R33 Stock wheels
$100
R33 Emergency tyre
$50
Edited by MAS_R33
  • 1 month later...
  • 5 weeks later...
  • 2 months later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
