I am the original owner having bought this car in 2001. This car has been used as a daily driver and has never been mistreated. The car has garaged and serviced regularly with quality oils and parts.
I have used high quality name brand parts and I hope I can remember all the inclusions over the last 13 years. The reason for sale is that Ms. Wolv is the proud owner of a new, slower and lardier Korean car so I am moving my plates over to the RS4S.
This is a regretful sale, will suit the buyer who is looking for a car that is in very good condition, quality parts fitted, tuning by one of the best in Sydney and nothing more to spend for the next few years.
The car is registered until February 2015. The car has 240,000km on the clock. I changed the original engine (compression was good) for a lower km Stagea engine. Timing belt, waterpump, idler bearings, and all belts were changed at the same time (less than 20,000km ago).
Car: Nissan Skyline GTS-t series 2
Drive train: 5 speed Manual RWD
Engine: RB25Det
Colour: Silver
Kms: 240,000
Price: $11,000
Reason for sale: Missus has bought a new car so 3 into 2 doesn't go
Contact: 0407 669166 or pm.
Modifications:
Garrett GT3076 56 trim comp 0.82 turbine twin scroll housing V-band rear
HKS cast manifold extrude honed, low mounted externally gated (suitable for T3 or T4)
Plazmaman FMIC
Jim Berry Clutch higher clamp organic
Apexi pod filter
Alloy intake
Greddy Profec B type II
Apexi Power FC + Datalogit + Wideband
550cc injectors
Bosch 984 fuel pump
Bilstein shock absorbers front/rear
Kings Springs front/rear
Whiteline adjustable swaybars front/rear
Camber adjustable eccentric bushes front/rear
Polyurethane bushes, pineapples etc
Aftermarket castor rod pickups (front end turn in is exceptional)
UAS (Bosnjaks) brake master cylinder stopper
Venom 5" cat
3" straight through exhaust, quiet exhaust note. Will supply rear cannon if you like the sweet RB sound
Splitfire coilpacks
Fenix 42mm alloy radiator
Volk Racing Wheels
JVC KDR926BT
Focal splits
Audison SRx3 amp
JL Audio 10" subwoofer hidden
Sound deadening installed inside front doors and under rear seats
That is a very very old tune which was done 3 years ago. Do you have any more recent dyno paper?
And? Makes no difference dude. Ignition/Fuel maps don't change by themselves with age lol
Can't believe you're selling her!!!!!!!
Ferk it's clean, you sure take good care of your car mate!
Good luck!
I can vouch for this car its clean as a whistle top shelf mods and tune! Car has power everywhere it really is a great drive! If you're in the market for a 33 give ya money to this guy and drive away in this silver bullet :)
Just realised you used an overlay of my 98 tune lol!
Edited by Mick_o
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
