Hey guys stripping r33 skyline got heaps of parts ask for wat u need
I'm located in werribee number is 0426296161
R33 tail light $50 each
R33 rear garnishes $20 each
R33 series 1 grill $20
2x clutch pedal $150 each
2x brake pedal $100 each
R33 slave $50 each
2x r33 floor matts $70 a set
R33 stock intercooler $90 good for clearing defects
R33 3inch cat back exhaust $200
R33 lsd diff $150 each
Greddy turbo timer $30
Pivot turbo timer $30
R33 indcators 3 sets $20 a pair
If u need other parts guys don't be shy to ask
https://www.sau.com.au/forums/topic/442107-stripping-r33/
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
