Hi fellas,
I started this topic to see what kind of results some guys are getting on an engine dyno around the 600hp+ mark. In particular, actual engine torque values and rpm it is achieved (instead of measured by rolling road dyno).
So, anyone tuning on an engine dyno and have some torque figures to share; nothing specific, RB26, RB26, RB30... sorry if this topic is conflicting with the dyno result thread but it it more specific to engine dyno.
Thanks,
Mike
https://www.sau.com.au/forums/topic/442160-rb26rb30-engine-dyno-results-600hp/
I have only ever heard of maybe two RBs being tuned on engine dynos, one RB25 making ~1400hp and one RB26 making ~1700hp - probably not too helpful for this topic, most people aiming for "only" 600ish are content with a rolling road or hub dyno :)
600hp+.... they can post it in here!
I know BoostdR had some results, I can't find it however. It was an RB30 with twin -10s that made good strong power.
I don't know of any tuners or engine builders here who have an engine dyno - the only ones I have seen are in a Polytech and one in a place doing research on fuels - which is not to say that there aren't some somewhere. I have seen a video of an Aussie speed shop somewhere that has one.
There are a few in Adelaide; most would not go to the trouble of an engine dyno but IMO it is the best way to tune and run in an engine prior to fitting it to the car. Also the only way to get a true reading of torque (and engine power).
There is one up our way, costs by the time you wire it all up etc are a bit steep, we were thinking to do the run in and basic tune on it and makes life simpler if you want to inspect the engine internally or work on it, in our case we are still unsure if its the right thing for us.
Maybe. maybe not.....
Yeah mine was done in Adelaide prior to me buying it.
2.8l with turbonetics GTK850 25psi on 98 with 10% meth-- 760hp & 780nm @ 5500rpm from memory.
Will try and find the sheet.
Thanks Richard, I will have a look for BoostdR's result somewhere on the forum today too.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
