ok guys im only new at this and i dont even know if i am in the right place but here go's.
i have a 1994 r33 rb25det s1 and my check light is on the dash...
the light comes on for a while then goes out for about 5 sec then appears again for a min or so then go's out for a couple sec and so on
i have done some reading and i have learnt how to bridge to loom to do a diagnostic, but the problem is the engine light dose not flash any codes at me when i do this
can anyone tell me why this is and how can i get the codes out of my ecu
this is my first skyline i have owned
any help will be muchly appreciated
https://www.sau.com.au/forums/topic/442696-check-engine-light/
ok maybe you arnt bridging the right pins, turn your ignition on and when you bridge the pins the engine light will turn on, keep it bridged for a few seconds and then release the pins and the engine light will flash your codes at you. The only alternative is to hook it upto a consult program an a laptop using something like datascan, you will need a special cable to do this
What ecu are you running? The consult port will only work with a standard ecu.
As for the port itself, it's called 'Consult' and is pre OBD2. You need to get a special cable and software to use it. Check this out:
http://www.ecutalk.com/interface.aspx
that is a very good point, if you are bridging those exact pins in the picture and nothing is happening you may have an aftermarket ecu, some are a full replacement and some just change the circuit board in the original one, rip the passenger side kick panel off and have a look, if you see apexi or something like that on it then its aftermarket
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
