I was not born in the computer generation ,sorry,Thanks Greypearl.
Um.....it's the computer generation we usually have the most trouble with not being able to form readable prose.
The rules for written language are quite simple.
1) Have an idea you need to convey.
2) Put together words to convey that idea. Use just enough words to correctly convey that idea, then put in a full stop. If one sentence won't cover the whole idea, then start again with a new sentence for the next part of the idea.
3) If you have multiple ideas to convey, repeat the above for the next idea and so on.
4) For breaking up major different ideas, press the enter key a couple of times so you get a new paragraph.
Also, numbered lists like I have used above can be convenient ways for people to address individual points you are raising. They can refer to your numbered points. It's great.
  • Like 1
Thanks GTSBOY so simple when you know how
1) Need to know which are best and why BC'S or Bilsteins.
2) Bear In mind that my car will probably never see the track.
3) Cost is a factor,Cheers Greypearl.
Edited by Robert Knight
  • Like 1
If you want some help making a decision go to the top of this page to the "pinned" topics and read " shockabsorbers 101" by SK.
SK has designed suspension set ups for Skylines and Stageas and I have followed his plans for my Stagea :
Bilstein shocks front and rear (but with Tein springs - missed out on the group buy) and heavy duty anti-roll bars.
I also have adjustable castor and camber arms but set fairly conservatively for the street. I ran 3 deg neg camber at the front and 1.5 deg at the back with my slicks which was great on the track but chewed out my street tyres so I toned it down a little to 1.5 deg front and rear. Tyre wear has gone down but my heavy wagon still handles pretty well on the road.
After maximising the caster (we can never have too much caster on an R32/33/34) I would have gone for 1.0 to 1.5 degrees negative camber on the front and 0.75 to 1.25 degrees negative on the rear. R33GTR are predominantly understeerers due to the ATESSA calibration and HICAS programming, so I also find around 2 mm toe out each side, front and rear, to be beneficial.
Having sorted the wheel alignment the choice of dampers is a pretty simple one, I have found Bilstein work well on R32/33/34's due to their sophisticate valving. There's about 300 or so kits utilising Bilsteins in Skylines, Stageas and Silvias running around from the old Group Buy days and the guys seem pretty happy with them. Depending on the budget non adjustable, single adjustable with or without remote canisters or triple adjustable with remote canisters.
For non adjustable I'd suggest Kings springs (Lows NOT SuperLows) as Redranger in their infinite wisdom discontinued all Whiteline springs. The Bilsteins I do have my valving specs and come with additional circlip grooves so the cars ride height can be selected prior to fitting them. For R33GTR's I never go lower than 355 mm on the front and 345 mm on the rear (centre of wheel to guard as usual) as the ride deteriorates and the suspension geometry is not designed to operate at lower than height.
If finite on car height adjustment is desired then Eibach are the best spring choice. They require the addition of what we call "coil over conversion kits" to the Bilsteins.
Always remember that swaybars are by far the best value handling upgrade, road or track. You have my email address if you want to discuss.
Hope that helps
Cheers
Gary
  • Like 1
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
