Hey guys, I've done a fair bit of research but found nothing on comparing the two, Greddy/Trust vs Precision.
So i have a built rb25 with pom cams and my current setup puts out 320rwkw @ 18psi on bp98 fuel with Genuine Greddy td06sh 25g. I get full boost roughly around 4-4.2k revs and hits hard from then. For me thats a bit laggy for street use. I want similar power with much better low to mid range and more linear rather than on/off power.
I was looking into precision turbos as my bro has one on his xr6t and gets full boost from 2.8-3k and freaking 412rwkw on 18psi. PT6766… blooddy 4L fords are crazyy
Now i was looking at Precision 5858 or 5830 or even the 5557. All the billet twin ball bearing with anti surge housing. Will be low mounted with his cast manifold.
So do you guys think i will get a worthwhile improvement with any of the precision turbos over the greddy td06?? power wise and response
cheeeeeerssssss
https://www.sau.com.au/forums/topic/442895-rb25-turbos-greddy-vs-precision/
you have to take it off the manifold if its highmount its really not that hard way easier than spending cash on a new turbo you don't have to
the rear housing will have a 8 or a 10 on the casting were the exhaust gas enters the turbo (for lack of a better explanation)
I may even have a buyer for the 10cm rear housing for you :)
tutumiwo-img600x491-1298788614r9wz2u1802
Edited by 1400r
With that sort of response on an RB25 you are running a 10cm housing. Going from a 10cm to an 8cm housing on that sized turbo will really liven it up in the mid-late 3,000rpm brand but say goodbye to having any pull over 6,250rpm.
I went from an 8cm and tried a 12cm because I couldnt get a 10cm housing and the 8cm was wild. 300rwkws and the think just blazed tyres with so much extra torque down low. Would suggest the 8cm will run better on E85 as it is too small IMO for a 2.5L engine and E85 masks such mismatches.
I ove my Trust turbos but if you want more response then time to change turbo...not pay $400 for a different turbine housing and have a compromised result
E85 won't give you better response; as in, it won't affect the turbo lag. You can tune to have it feel more 'gutsy' off boost if you like, just ask the tuner. Your fuel consumption will suffer though.
If you want the same top end power and better response you can use a smaller turbo increase boost. 18psi is pretty low for a built motor
OR you could go for a smaller turbo, more boost + E85 for even better response and top end.
Whatever I guess it comes down to how much time and money you want to put into it
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
