1997 Nissan Stagea, RS-4. (AWD Turbo, RB25DET) Automatic
Have put a lot of time and effort into this car, Non Smoker, Rego till June 2014
Has been kept very clean inside out, the interior still looks brand new with no marks, fades or damage to the seats.
*PRICE LISTED IS WITHOUT WHEELS* comes with 17" GTT Stockies
I have converted the front end to a BNR34 (R34 GT-R, Z-tune)
All parts purchased, via Import Monster.
The front end has been resprayed and colour matched to the factory pearl white paint which is still in excellent condition all around. Car is in good nick all around,
I do require to fix a few minor issues before sale such as the bonnet struts that hold the bonnet up as need to be adjusted a little bit better. (Am picky with how things look.)
Engine has not been touched/modified, apart from a custom front mount intercooler (return flow for legal reasons) no holes cut in body. I have only modified this car visually as I have just used it as a daily since ownership, have serviced the car every 10,000km's.
Parts consist of:
GTT Stockies
Custom Made 2.5" Return-flow intercooler (By JD Autoworx)
BC BR fully adjustable coilovers (height, damper, spring preload)
Genuine Seibon Carbon Fibre Z-tune Bonnet
BNR34 Z-Tune front bar
BNR34 Z-Tune front lip
R34 Xenon Headlights + HID Kit Installed
Nismo front clear indicators
Custom R34 front wide guards to suit stagea body
S2 Stagea clear taillights
Genuine stagea floor mats.
Custom plates included: STAG34
Alarm + Immobilizer.
The car will be sold with ALL the stock parts i have for this car, which includes the entire stagea front end: front bar, all lights, indicators, guards, even have factory option items which i have not had a chance to put in such as the dual factory twin sunroofs + more.
More than happy to throw it all in + some more goodies I have for it, take it all as i will have no use for it once the car is sold.
This is an awesome daily/cruiser, great to drive day to day and turns a lot of peoples heads as you drive past. Kept it and simple, looked after well and is a perfect example of a clean stagea!
Please contact if genuinely interested, no test pilots. $16,000
If i do not pick up please feel free to send a text message through and I will get back to you as soon as i can.
Thanks
  • 3 weeks later...
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
