Hi guys considering doing the smart thing and bailing on my build considering things have changed in my life
I will only be parting once I get the big items pre sold shell engine box
R34 gtt Stat write off can't be rego'd shell had a front end smack pulled straight rad support not mint needs a bonnet, sus and wheels to roll $3,000 ono
(not interested in your thoughts as I've spent a fair bit to get it looking ok again)
25 neo engine no ecu or injectors $1500 proven running motor not some wrecking yard unknow can be comp tested by buyer if needed
34 25 5 speed box $1500 firm
ORC pull type twin plate clutch $750 firm
HPI R34 Alloy Rad $280 firm
Blitz return flow intercooler brand new in the box $500 firm
r34 gtt fcon ecu and patch loom tuned for cooler and exhaust round 220rwkw atm (info from prev owner) $400 ono
cat back exhaust unknown brand $500 ono
Chinese r33 front pipe brand new $80
Chinese r33/4 dump pipe brand new $50
Kando brand new external gate T67 $850 firm
Kando rb bolt on TD06H 20g internal gate brand new in the box $750
K sport R34 gtt coilovers $600 firm
r34 gtt nistune $500
Turbosmart 45mm gate brand new in the box bought from mtq so legit $385 firm
walbro E85 450l pump brand new $150 bought from mtq again
ev11 or whatever 25 neo 1000cc injectors fitted but not fired again brand new from mtq $550 firm
feel free to mesg me if you have questions
if I don't get what I'm after I'll just put it on the back burner
041
1152
733
Edited by 1400r
If you don't mind me posting up Ryan I've got the triple gauges for the other member.
Also have a mint front section that was cut off my car and ready to go on this if anyone wants to fix the rad support etc properly.
  • 3 weeks later...
    • Hey, I understand this is a skyline forum but I was hoping someone might be able to help me out here. Got an ‘84 M10 Prairie with an E15S that I’m trying to get running again after replacing a head gasket. I’m having some struggles with vacuum lines after replacing a couple perished ones. They’re all set up like in the diagram I’ve attached. I’ve tried starting the motor and my carb backfires a bit but no luck getting it to run.      Theres a 2nd port on the back of the carb that isn’t mentioned in the diagrams, right next to what I believe would be the idle screw (sorry I’m no good with carbs) - should this be attached to any lines?   any help would be greatly appreciated, I’m sick of pulling my hair out trying to figure this thing out 🤝🏼
    • If the current relationship is between the diff and the speedo, then no, you will not need a speed sensor in that hole in the gearbox. If the car were an R33 GTST, or an R34 GT-T, then it would need a speed sensor in there. Because that's what those cars have/need. If the car were an R32, then it will need a cable drive cobbled together from a Navara speedo drive, because R32s can't handle an electronic speed signal to the speedo.
    • Just to follow up on this.  Will the speedo work with this? Like to have plugged speed sensor on this trans and still using one on diff from N/A (open) diff?
    • The opposite experiment is equally viable. 10L of petrol in the tank + 2L of metho.
