Guys i have stock 33gtr wheels on a stock r33 gtr and was wondering what tyre size i should upgrade to.
i was thinking
255 55 17 instead of the 245 45 17.
i would get 255 40 17 as tempe tyres has them for $160.00 a corner, but it drops the car 8.5mm lower and the spoiler hits everything as it is already.
Will a profile of 55 be too big and rub inside when turning the front wheels?
I need to raise the car a little bit as the spoiler hits everything and i want to fill the void (between the tyre and rest of the car).
Any help would be much appreciated.
https://www.sau.com.au/forums/topic/443431-tyre-advice-please/
A different tyre size is not an "upgrade".
255/55 will be far too tall. If you were to go up to a 255 you would only do it with the same as the original profile....that being 45. The tyre will be 4 or 5mm taller in the sidewall, which is probably about the limit. A 55 profile in that width would be 30mm taller in the sidewall! And I will include another few !!!!!! just to reinforce that point.
Buy the standard size as first preference. Second preference would be 255/45. There is no other good option.
Tyre profile is not there for altering the ride height of the car. If you have a problem with bits of the car hitting bits of the environment, then you need to adjust the suspension to raise the ground clearance of the car.
i was thinking
Hi there, when nissan designed the gtr the designed godzilla. So 245-45-17 as nissan recommended would be the best size for it. We have 245-45-17 kumho ku36 performance tyres available.
St George Tyres
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
