  • 3 weeks later...
BAHHHHH!!! Looks like it will have to be next one :( You might have the time to qualify for both? That way at least gets you some point still if there is less than ten racing ;)
Bathurst + V8SC is difficult enough without trying to mix up the MX5 or spec racer lol
Haven't fired this up for ~2 months but not sure I'll be motivated enough to plug the wheel in tonight as I really dislike Charlotte.
Good thinking! Should be able to qual for both ;)
  • Like 1
Even with a smaller field the racing was still great!
here are results and championship standings as of round 5.
RACE RESULTS
10446238_10153421698084386_3521922310520
CHAMPIONSHIP STANDINGS
10270472_10153421698059386_4264273845010
Next month is the last round for the year. For this round there will be a vote held on which track should see the finish of the SViRC.
So have a practice on some tracks find your favorite and keep your eye out for the voting poll! :)
  • Like 2
  • 3 weeks later...
So time for a vote on tracks for the last round of the SViRC. There are 5 tracks to choose from each being one the series has already seen a race on. Will tally the votes the morning of the 5th of November which is the day of the last round.
Tracks-
  • Lime Rock Park (USA)
  • Okayama (JAP)
  • Laguna Seca (USA)
  • Summit Point (USA)
  • Charlotte (USA)
To vote just reply here with your choice and hope to seeing everyone at the last round :)
Unfortunately I'm doing a go karting championship in Canberra and the next date falls on the same as this :(
If the go karting finishes before 9 I'll rush home and try and jump on but I'm not holding my breath.
I think you've got this series in the bag Tony haha! I'm sorry I didn't participate more. Thanks for hosting it. More numbers would have been nice, not that I can speak. But I suppose most things start small and grow.
Last race tonight!!! If you would like to vote for a track still you have till 6pm tonight to get you vote in. If theres no votes a random track will be picked from a hat (or beanie). Hope to see some people there and racing :)
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
