HI Guys
some help here please
so I have rebuilt my rb26 from scratch, flowed and ported head with Tomei poncam type-b
so first install with rc750cc injectors and Mine's mafs brings no joy, idle is rough afr erratic, i can lean the afr out completly and it would still run rich
replaced the mafs with old mafs and old injectors still the same problem
the car came with bov's that vent to atmosphere I have disconnected them they are not leaking at all when disconnected
when driving the car it hesitates alot but when turbo's start making neutral pressure 0bar the AFR starts to lean out then when on boost its start riching up like You would expect and it feels pretty solid on boost with no issues
any suggestions
could the cams perhaps be out to overlap and cause an issue like this?
Thanks hope somebody can shed some light
https://www.sau.com.au/forums/topic/443517-gtr-low-rpm-richness-and-hesitant/
are you using the same map loaded on your powerfc as before? i recommend, if you can...to do a data initialise (wipe) of your power fc and then reload your maps...then run through the startup procedure for the powerfc again. if you can't do this...i'd recommend taking it to a tuner that can.
I have initialized the apexi so with stock injectors and mafs you would expect it to idle like normal but no luck, its just beyond rich and adjusting the correction does not lean it out
I am thinking that the ovelap of the cams 35degrees is maybe losing some of the air in the chamber and causing the richness
but driving at low RPM is also horrid so much hesitation
if it's a fresh build perhaps cam timing is out? how big are the type b's? I thought they were pretty streetable AFAIK.
Also, not that it would matter in idle but you can't tell if the Bov's are leaking without pressure testing
I sparyed some quick start in the bovs while idling with no change in idle
paid so much attention to the timing when assembling the motor but will chack again
does anybody know what would be safe degrees to start off with when degreeing these cams could maybe close some of the overlap
cam specs below
B
260°
260°
9.15mm
9.15mm
110°
115°
0.45mm
0.38mm
You can calculate overlap here https://www.rbracing-rsr.com/camshaft.html
with these settings
Tomei Poncam B
Intake 260 degrees 20 BTDC 60 ABDC 110 degrees
Exhaust 260 degrees 65 BBDC 15 ATDC 115 degrees
check your o2 sensors.... They could be poked. unless you have o2 feedback turned off. either way if you are not able to tune it.. try getting it Tuned.
The cams wont cause the issues you are having, unless installed incorrectly.
I only recently installed type B's into my neo and it has been running fine with no change to the tune (havent had a chance to get on the dyno yet)
ok so Update
I checked cam timing according to true TDC everything is spot on
I did a compression test on the fresh motor couple of km's on it and it was super low 6bar 87psi cold, could be due to cams and not run in yet
I am at a loss here and I feel I want to burn this fekker :/
so when on idle now it would be on 12 afr but very rough as soon as i want to rev it up slowly it starts leaning out up to the point that it wants to die
when I leave the throttle it wants to die aswell then i need to sort of keep it alive, I am now getting a set of standard recirc bovs in hope that that can help but wont bet my life on it
Yes I do have bigger injectors
I have RC pl4-750d 750cc injectors, played alot with the settings and ended up on 59.2% and +0.24 lag time
this seems to work best, if anyone has used these injectors with apexi would you mind sharing your experience and settings please
try this:
  1. Reset PowerFC
  2. Set scaling in ball park
  3. Select correct AFMs
  4. Turn off O2 feedback
  5. Start/Rev car up to around 3000 rpm & hold (when warm)
  6. Adjust scaling till car hits stoich (roughly)
  7. let it idle, then adjust lag time till idle is stoich (roughly)
  8. tidy up map
  9. Enable O2 feedback
  10. Take to tuner
These are the Lag times i could find for the injectors.
Injector Flow CC/min Flow LB/Hr Ohm 10v 11v 12v 13v 14v 15v
Nissan Skyline GT-R 440 42 2 1.35 1.12 0.96 0.85 0.76 0.65
Nissan Skyline GT-R 440 42 2 0.7 0.61 0.54 0.48 0.4 0.35
RC Engineering 750 71 3 0.57 0.48 0.38 0.31 0.24 0.17
RC Engineering 750 71 3 0.88 0.66 0.48 0.32 0.18 0.05
RC Engineering 750 71 12 1.36 1.12 0.92 0.76 0.63 0.5
Edited by Badgaz
Update
I think I resolved the issue here
did a silicone grease trick on the ignition coils
degreed cams a bit +2 intake -4 exhaust
installed stock bov's recirculation
now with the setting of 59.2 and 0.24 on the injectors it idles almost perfect 14.7
acceleration is also almost find just a bit of leanness when initial pushing of the throttle
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
