Guest krisd Posted October 3, 2002 Share Posted October 3, 2002 I have a series 1 r33 and am wondering if all 4 headlamps should be on when it's on high beam. When mine is put on high, one pair goes off and the others go on. Is this normal? Link to comment https://www.sau.com.au/forums/topic/4438-r-33-headlights/ Share on other sites More sharing options...
SkylineMannen Posted October 3, 2002 Share Posted October 3, 2002 Originally posted by krisd I have a series 1 r33 and am wondering if all 4 headlamps should be on when it's on high beam. When mine is put on high, one pair goes off and the others go on. Is this normal? yes it is normaly... have thinkt the same but it should be so anyway. =) Regards Klas Link to comment https://www.sau.com.au/forums/topic/4438-r-33-headlights/#findComment-69846 Share on other sites More sharing options...
NismoGirl Posted October 3, 2002 Share Posted October 3, 2002 I think all R33's are meant to do that. Well mine does and every other one i've seen does. Unless all of ours are broken... But yes. I pretty damned sure that they are meant to do that. Link to comment https://www.sau.com.au/forums/topic/4438-r-33-headlights/#findComment-69848 Share on other sites More sharing options...
Guest krisd Posted October 3, 2002 Share Posted October 3, 2002 Hey, thanks guys for the replies, my mind is now at rest Link to comment https://www.sau.com.au/forums/topic/4438-r-33-headlights/#findComment-69857 Share on other sites More sharing options...
DAMQIK GTS-T Posted October 3, 2002 Share Posted October 3, 2002 Im considering running a couple of diodes from the hi-beam to the the low-beam, so all four will go on at hi-beam (this is done at the relay's) (for those thinking of doing the same). DAMQIK Link to comment https://www.sau.com.au/forums/topic/4438-r-33-headlights/#findComment-69874 Share on other sites More sharing options...
akeenan Posted October 3, 2002 Share Posted October 3, 2002 YES IT IS NORAML THE GLOBES ARE SINGLE FILIMENT THAT IS WHY Link to comment https://www.sau.com.au/forums/topic/4438-r-33-headlights/#findComment-69959 Share on other sites More sharing options...
XrSiSt Posted October 4, 2002 Share Posted October 4, 2002 Originally posted by DAMQIK GTS-T Im considering running a couple of diodes from the hi-beam to the the low-beam, so all four will go on at hi-beam (this is done at the relay's) (for those thinking of doing the same). DAMQIK I think it was East Bear who have this kit. Its for sale at Perfectrun. Link to comment https://www.sau.com.au/forums/topic/4438-r-33-headlights/#findComment-70035 Share on other sites More sharing options...
puckish Posted October 4, 2002 Share Posted October 4, 2002 NO the series one the inside ones should be on only during high beam. I checked the wiring and this was the way it was suppose to be. Link to comment https://www.sau.com.au/forums/topic/4438-r-33-headlights/#findComment-70310 Share on other sites More sharing options...
Jay95R33 Posted October 4, 2002 Share Posted October 4, 2002 Originally posted by DAMQIK GTS-T Im considering running a couple of diodes from the hi-beam to the the low-beam, so all four will go on at hi-beam (this is done at the relay's) (for those thinking of doing the same). DAMQIK I'd be keen to know how you go with this. By memory I think that kit is about $150-200 :eek: Link to comment https://www.sau.com.au/forums/topic/4438-r-33-headlights/#findComment-70313 Share on other sites More sharing options...
