Good afternoon SAU,
I was driving to the shops this morning and the following happened -
  • The HICAS light came on and off (sort of flickering)
  • All tachos were bouncing when the above occurred
  • There was no power steering when I entered into 1 of the turns
  • The car stalled twice (once when entering a round-a-bout and when entering the car park)
However, the above did not occur permanently but was on and off. I managed to get home and performed the following -
  • I disconnected the leads from the battery and re-plugged it to try and reset the ECU.
  • I tried to perform a HICAS Diagnostic as per the link below but didn't quite understand it:
http://www.skylinesaustralia.com/forums/topic/22193-hicas-diagnostic/
After doing all this, I took the car for a 2 minute drive and everything felt normal.
I'm still a bit worried though as it is quite dangerous driving a car that could stall any time.
I've been speaking with 'johnnilicte' (from this forum) who believes it is an electrical issue.
I was planning to take my car to the mechanic today but he was extremely busy.
Just wondering if anyone on the forum has encountered such issues before OR may roughly know what the issue may be.
Your advice is greatly appreciated!
Regards,
Lewis
https://www.sau.com.au/forums/topic/443828-r33-gts-t-s1-hicas-issue/
Yeah thats not purely hicas related. To many odd things happening at once. HICAS will not make the car stall. Sounds like a bad earth to me
So far so good after disconnecting and reconnecting the battery leads (touch wood)...
That's not a very technical solution...
I would actually clean the battery terminals and earth points points rather than hope for the best.
Thanks mate. I'll have a look into it next weekend when I've got some free time.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
