ive been listening around my engine bay intensely recently as theres a strange scraping sort of sound going on. the front end bearing of my gearbox is very worn so thats making a noise but there seems to be a scraping sound coming from near the turbo area.
its sounds like the wheels are scraping against the turbo housing. is this realistic? the turbo still spools up well and theres no loss in power... could this scraping noise not be the turbo? its driving me crazy!!
https://www.sau.com.au/forums/topic/4439-turbo-wheels-scraping-against-housing/
as macka said ive got a t04. i swear the scraping sound is coming from the turbo! but their appers to be no side effects, and when you stand over the engine bay and rev the engine it goes away... i really dont understand. macka mayeb you should swing by a have a look hehe:burnout:
have u leaned it out the turbo by running hi-boost and not having enough fuel?
if so, you have probably melted your turbine wheel and caused the turbo to go out of balance which might be causing the exhaust wheel to hit the housing.
check the shaft for any movement (in/out & left/right) from the compressor side, or get it checked out by a turbo specialist.
good luck.
nah i havent leaned it out that much
im running 12-13psi with a bigger fuel pump, and AF's around the 10:1 mark.
i might get it checked by a specialist... i dont know if im being paranoid or not though, because sometimes i hear it and sometimes i dont. also the front end bearing of the gearbox is gone and thats making noise around the same area so im not sure...
if it was scraping against the housing would it
a) be loud
B) occur under all conditions?
Guest Cob@lt60
Hi dude,
My standard R32 turbo started doing the same/similar thing the other day.. It makes a squeeling/scraping noise only when the boost starts coming on (around .5 bar)
I'm taking mine to the mechanics on Wednesday 16th (if it lasts that long).. They said perhaps the exhaust wheel is unballanced or missing a "vein".
It's slowly getting worse i think.. :);) *tear*
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
