So I changed my timing belt, tensioners and water pump but I was apparently not paying enough attention to the instructions and now I'm worried.
Before I removed the belt, I only lined up the timing marks on the two cam pulleys up top and didn't pay attention to the mark on the crank. I was careful not to move anything, but the belt was hard to get on so now I'm worried that something might have moved.
I haven't fired the motor yet and I don't want to until I know this is right. So any advice on what I should do? Is there anyway I can safely check that it's lined up correctly?
A screwdriver down the first bore can give you close to top dead centre, then make sure the marks are correct on the cams.
Make sure you turn it over by hand first a few revolutions. That way you can be sure the valves aren't hitting the pistons.
Ok so I need to get cyl 1 to tdc on the compression stroke, and at that point the two marks on the cam pulleys should line up? What about the mark on the crank - should that line up with the notch cut out on the bottom side, or should it be at the 0deg timing mark on the belt cover?
and if it turns easilly by hand (besides the resistance of compression) then the pistons arent hitting?
Edited by mistermeena
ah yep so when cyl 1 is at tdc, the crank gear mark will be lined up with the notch on the oil pump? And if it's wrong on the cam gears I need to take the belt off and adjust them in the direction closest to making them line up?
Seriously hope it all lines up lol
Belts are a bit hard to get on, abit harder when they are new. You have to get them started on each sprocket, idler & then tensioner, then evenly push the belt on all the way around, it's the easiest way.
If you have doubts, before turning the engine over, get a mirror & visually sight that crank & cam marks are lined up. Then, slip the lower cover on & sit the balancer on the crank nose by hand & see if your marks line up. Then if all good, release your tensioner, bar the engine over 2 revolutions, re-check all 3 marks. If it's good, then hold the eccentric in that position with an allen key (please, do not add more tension, your only causing premature stretch in the belt & loading the idler & tensioner bearings unnecessarily!) & torque up the bolt.
If your in Sydney I could come & have a look.
Correct.
Not exactly. The procedure is once you get the timing belt on, you rotate the engine backwards to put tension on the belt (Think it reccomends turning it over 3 times backwards by hand) then get an allen key to fit in the tensioner just to hold it in that position while you do it up.
I think thats right anyway. something along those lines anyway
Never ever turn an engine backwards (anti - clockwise)!
When fitting the tensioner, you need to wind up the spring so that after you have fitted the belt & release the tensioner BEFORE winding the engine over (clockwise) by hand, you actually already have spring tension applying force on the belt.
The whole purpose of winding the engine over (clockwise) is remove any slack from the installation process before torquing the bolt.
It just makes it hard to align the marks, as the slack is on the wrong side. Cam timing is important to get right.
I saw an RB26 actually running backwards the other day, both cams were 90 degrees out, set up like Toyota cam wheels accidentally. Exhaust was coming out the airbox and fresh air sucking in the exhaust. Once the marks were realigned properly it ran fine, didn't even bend a valve.
  • Like 1
Not to put too fine a point on it but with No1 at TDC you can still be 180 out on the cams.
So don't panic if the cam marks don't appear with No1 at TDC.
Turn the crank another revolution and then see if the cam marks are looking better when referenced against the back cover.
Don't take any notice of markings on the belt at this stage.
Not cranking an engine backwards harks from timing chain engines with hydraulic tensioners. With the engine cranked backwards, the spring pre-tensioner may be insufficient to keep the chain on the sprockets.
Yep saw the same one as you Scotty, the issue was they were black tomie cam gears and the dot was not highlighted in white, silly bugger set them up like 2Jz gears not seeing the dot.
When i got home i looked at my gears and the dots had a dab of white paint on them, go figure, maybe not genuine tomie cam gears?
I had a backup set of valves on my bench if he needed them, didnt in the end, it surprised me.
That car ended up back on the hoist a few days later, they had setup antilag on it and a new clutch, owner spent the next day doing launches showing his mates and destroyed the clutch, never gave it a chance to bed in properly.....
Hahahahaha RB26 Honda engine!
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
