91 R32 Gtr // Doors And Rear Window Rubbers Any Helpers ?
If your looking for new RHDjapan sell these. Use pinpoint search on their site.
It is very Difficult to get good second hand external weather strip surrounds for the doors. You could remove (piss easy, screws on inside under weather strip) and repair by taking back to metal and repaint with Plastidip or similar paint.
For the rear window a car glass replacement company could remove/replace with an aftermarket bead. Do recommend.
Make certain you have no rust happening and if you do take action !
I do happen to have spare new beads for the rear window if you want to stay OEM.
Not easy to install. It's not a DIY job and will need to be held in place by the sillastic the pro's use.
Edit. Just noticed your door glass marks. Maybe just from washing and water marks.
But to clean. Remove the outer weather strip sills on both doors and clean the little buffer pads to stop your glass from scratching up. (those 2 lines on the door glass)
These collect dust and little stones etc... Single screw inside the door, lift gently. When out wash and ruff them up a little with a toothbrush and then put back on.
The glass can be polished with metal cream, polish, toothpaste or other non abbrassives. It will reduce any visible scratches.
Edited by Sinista32
  • 5 weeks later...
Man thanks heaps for that.. Really appreciate everything uv said and il do that she's just sitting ATM need a service lol I have already brought the back rubbers but it's only the outer pieces and I wonder if I need the bottoms :/ payed 350 .. 175 ea as they come in 2pc. Still need to get the door ones .. Will check out the site u suggested... Thanks again man ... Are u in nz ??
Sent from my iPhone using SAU Community // NZ AUCKLAND
Hey guys,
I am trying to find the same parts at the moment. Have been searching all over RHDJapan's site and have come up empty handed.
If either of you happen to find them on their website, could you link them here so I can grab them too? In the mean time, I'll keep searching and will link to them if I find them.
Cheers.
Updated
Sorry post cleared :(
For both sides the Rubber and retainer is $800 posted
here are the links (again)
http://www.rhdjapan.com/nissan-oem-body-side-weatherstrip-bnr32.html
http://www.rhdjapan.com/nissan-oem-left-side-weather-strip-retainer-65f00.html
Cheers
Edited by Sinista32
  • Like 1
  • 4 weeks later...
  • 3 weeks later...
#3 Tut-tut...
I would never go out on loose gravel roads to do such a thing...
...unless the rubber mouldings were included on the PDS juxtaposed to windscreen replacement ;)
  • Like 1
  • 2 years later...
digging up an old thread. In regards to the first photo where the rubber has fallen away and you can see the metal .. is that part the weather strip retainer? I need to order new ones but I'm finding it hard to know which part it is exactly.. ( I have no yet received my car to take the part off and get a better look at it for reference)
is this the part
https://www.rhdjapan.com/nissan-oem-left-side-weather-strip-retainer-65f00.html
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
